SOLD NC: 1989 brown FJ62 interior and misc engine parts electronics
Additional items
Coil with igniter assembly. Tested and working.
All prices are + shipping unless noted otherwise.
Visors: Sold
Front lower footwell corner covers: $5 each
Driver side seat adjuster: $60
Hatch access covers $5 each
Dizzy boot: $40 shipped
Arm rest: $5 each (3 only)
Rear speaker set with grill, mesh, mounting, speaker: Sold
Rear speaker brackets: Sold
Window relay green: Sold
Glove box door (minus lock) $10
Door handle brown bezel (3 only) $2 each
Rear 3 point seat belt complete ($225) with vinyl brown wheel arches: $250 shipped.
Front seat belt receivers: sold
Hood spring hinges: $15 each
Air box minus MAF: sold
MAF: $50
Accordion tube and connector: $30
Distributor: $60
Rear seat carpet holder metal trim: $10 set, 3pieces
Ignition cylinder + glove box cylinder with 1 matching key: $60
Lock cylinder driver, passenger, gas door (no rear hatch): sold
Rear seat upper latches: $10 each
Washer bottle: sold
Window regulators: sold
Rear wiper motor: sold
Steering column assembly, with upper bracket, less ignition cylinder : $150
Center console: sold
Steering column clamshell: $100 shipped
Steering wheel: $300 shipped
Ac dash control unit: $50 shipped
Complete instrument panel: $150
Mirror switch:$5
Ash tray:$5
Indicator/wiper stalk : $125 shipped
Ac trim plastic: $75 shipped
B-pillar covers: $30 each
Rear vertical plastic trim :$30 each
Rear heat switch with new sticker:$15
Rear tool access cover: sold
Left Rear speaker panel: sold
Washer access plastic cover: sold
Brown door cards: Driver $30, front passenger $25, left rear $25
ECU computer tested /working: $175 shipped.
looking for rear seatbelt cover panels
FJ62 radio: radio works, illumination works, cassette players not working, LCD issue on left side. No brackets.
Any chance you have the gas tank skid plate (protects the filler hose, etc)?
ok, thanks.
I actually hate to ask you about such a small part I need, but I parted out a 62 a couple of years ago, and I can't find ANY of these I had.
What I need is the floor drain plug on the driver's side front foot well. There's only one, and it sits in a little indentation in the floor toward the left side. A 62 floor is the same as a late floor 60, so below is the photo of my '86 60 floor with that plug missing.
Please let me know if you have one, and if so, what you want for it. It can be mailed in a regular letter envelope.
Thanks,
David
Thanks,
David
Sorry, I did not pull / have that part 90950-01450.
OK. Thanks for looking.
I had thought I could get something that "generic" from Toyota, but they've already discontinued it..........yet you can still buy something big like a complete dash pad. Go figure!
Did you check out this thread?
Oh wow! I would have figured needing one of these would be so rare, I might be the only one looking for one....the thing that makes me so angry is that I pulled all the plugs out of both the 60 and the 62 I parted out, but I can't find where I put the bag of them!
Thanks much for the thread link! I'll check on some of those sources........................
