- Thread starter
- #201
For #1, see the post where I was wiring up the RCA connections, I know I noted how to determine the "-".Finally starting to tackle this project after having the parts sitting in my garage for 6 months and I have some questions that hopefully someone can help answer. The head unity I am installing is an ATOTO S8 (Gen 2).
1) With the RCA cables, is the ground wire what would go to the corresponding "-" terminal? ie "FR -" would be the exposed wire? I'm also assuming the corresponding wires on the harness that came with my head unit I just ignore and tape off, correct?
2) Is the "10" pin what would correspond to a wire labeled "Accessory/Ignition"?
3) I'm assuming pin "1" is battery?
4) I have a wire labeled "Rear Camera +" to switch the screen to the backup camera it came with. Where exactly should this be connected to? Should I just run a wire to the reverse lights or is there something more practical and less likely that I'll screw up?
5) Any ideas where a wire labeled "Steering Wheel Key +" or "Steering Wheel Key# +" would go? This is apparently combined with the ground pin to power the 3.5mm jack that controller the aftermarket steering wheel control that I have.
Thank you y'all for the assistance.
2-4 I would have to go back and read through here, you will probably be fast at that since you are more motivated.
For #5, I did not add any steering wheel controllers, so I will not be of much help on that one!
