Mystery Battery Tray Bracket
Paint Lick, KY
Website
www.globalsoftware-inc.com
Ok. Can someone tell me what was supposed to bolt to this bracket? It's not shown on SOR's site nor can I find it in the FSM. It looks totally stock?
Pulled all this off last night to de-rust it and get it powder coated. I plan on bolting my marine gas/water filter with large spin off filter here unless something inportant is supposed to be here? :-)
oem fuel filter
Yup. Early ones had a glass sediment bowl and replaceable filter element. I took a OEM remote oil filter mount and drilled out the passageways, found a fuel filter for it and mounted it under the battery tray. I'll post a pic when I get home.
GL
Ed
EDIT: Found a pic of IDave's that I pilfered:D
Ask and ye shall receive!
Can't help but notice my bracket is a bit different than the cool glass filter bracket shown? Mine is a 2/71. SOR shows that exact bracket you have the pic of for my year.
BTW there is a glass gas filter on E-Bay right now if anyone is interested.
Well, Dave has two trucks, a '64(?) FJ45 and a '70 FJ40, but I don't know which truck that is a picture of. Mine is a '66 or earlier(titled as a '66 anyway)
and had that same bracket like Dave's.
GL
Ed
Coolerman, it looks like this one might have mounted there on your bracket....
The filter bracket I am using there in the FJ45 IS a later (1970 style) bracket. However, I don't think there's much if any difference between the earlier and later brackets. Here's an illustration from an old engine manual:
Cooler, I found the pic of it mounted to the battery tray...here goes. The bottom of the filter is above the frame rails. I may change where it is mounted, but so far, so good.
Ed
Yes, I think that is the case. With the Marine setup I guess I will have to get one of those chrome propellers for the rear of the FJ! :-)
Ed
Yep that is the exact filter housing I have. I was going to powder coat mine pewter. :-)
This is whats on my 66 and its avalable new not too much $
Dusty, what is the story on those cool crimp-on clamps? As we say here in my little burg....."Them are cool!":cool:
Cooler, so you used a OEM remote filter housing? Or did you go marine?
Ed
Got em from GRANGER and thy have lot of different sizes I use the crimper tool mostly to repair heavy water hoses, the fuel hose I bought from a local House of Hose and thy gave the clamp rings as to use the old went-worth fittings you have to have the crimp tool :grinpimp:
....................................................................................Dusty
Ed
Ooops... Upon closer inspection of the red housing I see now it's not 100% identical after all! I did go with the Marine housing. It has inlets/outlets on BOTH sides for easy hook up. If you notice in my pic it shows the cross over numbers on the filter for several differnt boat suppliers. :-)
Here is one of the filter housing/brackets on E-Bay right now complete with the hose nipples for $9.99! http://tinyurl.com/zyp9a
