10 stainless steel 3/8" bolts is going to be plenty strong. Should look nice too.
I say grade eight, No need for the stainless as everything else will corrode as quick or quicker than the bolts.
Unless of course you are gonna leave them exposed?
the way the back angles out it looks like the axle could come back some for the 60/40 split. but it sure is comming along nicely, keep up the great work man !!![]()
Drew,
You may want to think twice about stainless bolts and stainless nuts. Stainless tends to gall when you thread the two together. I learned this the hard way; sometimes the nut will seize before the joint becomes snug. And if you continue to tighten it won't back off.
Just my .02.
The trailer looks great.
Mike
You might want to look through this reference:
http://www.mcmaster.com/
Scroll down to Fasterners and Sealing and then click on bolts.
You may not want to order the bolts from them (it's always nicer to go down to the store and pick them up) but it is a good reference for what is available. They list the tensile strength of the bolts so that you can compare the strength.
Steve
I use anti sieze on everything anyways
I am leaning towards the grade 8 now...
Thanks
IMHO grade 5 is as far as you should go. in the sport of wheeling the weight of the vehicles and what even the rock buggys do an grade 8 is more likely to fail due to shearing than a grade 5.
The theory on this is a standard bolt is too soft and smears, a grade 8 is too hard and will shear off without warning. A grade 5 will shmear a little before and appear loose before complete failure.
Just what we have been using in the northern midwest area the last 15 years.
This has been debated over and over again on Pirate and I will still take a Grade 8 over a Grade 5 any day of the week. The Grade 5 may "shmear" as you say, but the Grade 8 wouldn't be phased at that same load. It's not like they ultimately fail at the same load and one warns you while the other doesn't. The grade 8 is significantly stronger.
