Figured I’d start this as a chronicle of my OBA install. Started pretty innocently with an ARB twin compressor, but then @NLXTACY threw the rear quarter panel mount in the works and it all went to pot from there. One thing led to another and I’ve found myself essentially building a full air compressor system, complete with a 2.5G tank, 150psi auto shut off cable, regulator, manifold, the works.
The end result should be a pretty reliable 90psi air source with couplers in both front and rear.
For now, I’m just working on compressor install, wiring and initial leader hose to tank routing. I want this system to be completely hidden behind the factory rear panel. To do so, I’ve routed the leader hose below the compressor. Took some trial and error with different fittings, but a 45* 1/4mpt to 1/4fpt elbow did the trick. All fits snugly behind the panel.
