My "New" 97 LC
Arkansas
I just wanted to get some opinions and advice on several things from all of the experts here. I have had Toyota 4x4 trucks and 4-Runners since as far back as 1981. Never had better or more fun vehicles to own. Almost 20 years ago I helped a friend restore a 72 FJ-40 and I was hooked on the LC. I currently have a cherry 78 FJ-40 that is almost completely refurbished to new condition but still working on it. My son is taking over my DD 96 4-Runner:frown: (132,000 miles) in just a few months so I have been looking for a replacement and found a 97 LC with 159,000 miles:). The LC is completely stock, has been maintained at the local dealership, and garage kept. The body is close to perfect with just a couple of rock chips and one small scratch in the paint. It has new tires, no leaks, and the interior is perfect. It needs front brakes, the power antenna mast was broken (the belt that goes into the motor) and the front axle is making that low speed and turning noise that I have been reading about on here. Sounds like it needs a front axle service and the birfields swapped. The only other thing I could find wrong was that it needed a thermostat. It was apparently stuck open and not allowing the engine to heat up to temp. This allowed condensation to build up and cause moisture on the cap. That scared me at first, thinking the HG was blown, which brought the purchase price way down. But after changing the $14.00 thermostat and doing an oil change, there is no more moisture. I think I may have gotten lucky on that one. Oh, I forgot to mention the shiftlock problem I have encountered and received good advice about on here, but that is a minor thing. Other than what I mentioned, it runs and drives like a new one.
My question is......What else do you recommend I look at right now? What should I be concerned with? What should I not be concerned with? I don't have time to do the axle service myself right now, what should that cost to have done? Any other advice is appreciated. It is currently sitting n the garage and waiting it's turn once the 96 4-Runner goes into the hands of a 16 yr old boy.:):D
Thanks for everything!:cheers:
Scott
Welcome
The front axle service will cost you about $200 to do your self and about $1300 to have a shop do it. While the axle is torn down, you could easily add a brake job with very little additional work as you have to partially dis-assemble the axel to get to the rotors.
There is a thread titles FAQ for 80/LX450 series just below the announcements. If you scroll down to the maintenance section you can find a thread on the Front axle service with step by step instructions and pictures. Its not hard, just messy and takes a weekend. A lot of experianced folks will drop by for a beer if they are close by. Might put your location in your bio so it shows up.
The other item is to baseline all the fluids including the Collant, diff gear oil, tcase, brake fluid and power steering fluid. Tranny fluid is also a good thing. That with the front axle and new brakes should set you up well.
Thanks! I've already started on the fluids, getting ready to do the transmission this weekend. This is my first 80 so is there anything else I need to be aware of? Where is the best place to get a FSM besides just going to the dealer? And I've read about CruiserDan on here.......is he the best connection on Toyota Parts? How do I contact him? Just allot of newbie questions........
Thanks again:cheers:
SC
Yes, cruiserdan is the best connection on OEM parts, you can look in the classifieds tab for the vendors section, and should find a thread on how to contact cruiserdan at American Toyota, or the ad will come up in rotation at the top of the page and you can click on it.
