I am finally getting some lift on my 200. I have wheeled my 200 in Colorado, New Mexico and Utah on stock suspension and never had any major issues or could not get where I was going. I had a 3" lift on my 2012 Tacoma and got all the little annoyances that come with it like vibrations, noises, CV boot wear and crappy ride. The 200 rides like a dream and I really did not want to lose that. After seeing pictures with my 200 hooked up to my trailer I realized that I had to do something to keep it from sagging in the rear. I know I don't want a 3" lift so after much reading and help from people on here I decided to add the Firestone airbags and OME rear spacers (thanks for the write up @MScruiser) to help out on the rear. For the front I am doing the strut top plate spacer ( thanks @arich) This combo should give me the lift I need to keep level while towing the trailer and some extra room to tuck in the tires when needed.
I had some free time this past Saturday so I decided to tackle the rear part of it since I was still waiting on 1 front spacer from Toyota that actually came in today as I was at the dealership getting an oil change. The directions that came with the airbags are pretty good, but not everyone has done this kind of work before. Tools needed is very minimum. 12, 14, 17, 19mm sockets, 7/8 for lugnuts and impact guns help if you have access to that and a compressor. Floor jack and jackstands. And a big prybar. I started with the driver side by first opening the KDSS valves then proceeded to get the vehicle on the jack stands. Remove the lower shock bolt and rear sway bar bracket that attaches to the axle. Unbolt the rear diff breather and brake tube bracket from axle housing. Remove the passenger side stabilizer bar from the link. last remove the driver side bolt from the rear lateral rod. After this you should be able to drop the axle and remove the springs. Here come the pics.
GETTING STARTED
BEFORE
DRIVER SIDE OUT
CUT OE BUMPSTOP. (in firestone instructions)
ALL BACK IN WITH SPACER AND AIR LINE GOING THROUGH THE TOP OF THE SPRING SEAT
GETTING STARTED
BEFORE
DRIVER SIDE OUT
