Working fine on my end
Are you behind a firewall?
I am but never had a problem seeing pictures before. Its not blocking them.
I get this error when I click on them.
Field 'userfiles_dir' does not exist in data/settings/upl_settings.php
loads of pretty red X's.
The pics show up for me.
Where did you find the cone air intake?
It was Google Chrome messing it up, looks just as good as a Safari snorkle. Is it a Prefilter on the top?
That pre filter looks good, really the only reason I want a snorkel is the ability to have a pre cleaner.
Did you order from jdm-motorparts?
Snake, love how the snorkel turned out... I actually took my snorkel to my local Rhino-liner and they tried to just spray it doesn't sound like they tried to prep it at all. What kind of prep did you do before you lined yours?
Know what version they sprayed (TuffGrip, HardLine or SolarMax) or if they sprayed a UV top coat?
I used to be a Rhino dealer and basic spray doesn't have enough UV protectant and will fade within a year if the UV top coat is not applied
As for prep, I scuffed everything using 3M Scotchbrite (red), gave it a wash, blow dried, wiped down with prep-sol, air dried, then gave it a coat of PPG One Choice (plastic adhesion promoter), let it flash for about 20 minutes, then sprayed the Raptor and baked for 45 minutes
Gotta be prepped right or it just won't last![]()
I don't have a clue what they tried to use, I was in the area of the shop so I just thought I would drop in to see if they had made any progress and I saw it sitting on their table. Thought to myself that they hadn't gotten to it yet, NBD. Guy comes out and says the liner won't stick to it. No prep, looked just like when I dropped it off. I might just install it and see how it goes for the first year if it starts to fade take it off prep it and take it in then.
Thanks for the help!
98 SNAKE EATER said:OK, lasered some plates for the blank Safari oval
The plan is to roll them, bed line in tan and screw them in place
I also have the centers for the letters which will most likely be glued![]()
