My Distributor Eats Rotors?
Boise, Id
I haven't yet, but I will be going to Toyota and getting the OEM cap and rotor.
Has anyone else heard of this? If so, what's the fix?
10/72 F engine, it chews up the plastic notch and allows the rotor to get out of whack. This is the 3rd one in the last 6 months. I started keeping a spare rotor in the glove box.
Dan
I would say that the bushings are going out and that there is quite
a bit of wobble of the shaft relative to the distributor housing. This
should also show up jumpy timing if you have a timing light. I know
that Jim C. rebuilds older LC distributors but if this is the small
retard dissy, it's not worth it. Find a replacement.
Get a new non-USA Aisin VA dizzy.
Dave's solution is simpler, but expensive. New distributor = ~$300.00, new coil for said dist. = $70.00. Will I also need a Non-USA Carb? That's another several hundred dollars.
I'll try to rebuild this one first. I wish I could afford to just go buy new parts...maybe if I were to sell one, or two, I could afford to properly maintain the others.
There is something about having about 12 Land Cruisers in varying degrees of decay that can put pressure on the wallet (not to mention the marriage). (Did you end up buying one or more of those pigs from Poo-catello?)
You might be able to find a used retarded dizzy for cheap. Might be cheaper than replacing the bushing. I don't think I have my old one but I'll look.
I am certainly no expert, but it seems to me that you would want to match a vacuum retard dizzy to a vacuum retard carb, and vice-versa, or you would have some undesirable consequences.
rgentry said:
I bet I have an old dissy you could have for $15 bucks. Will be a vac
advance type, no sense of whether the bushings are shot are not.
I'll take it if he doesn't.
Sure its vac advance?
Dave- To run a vad advance distributor on a previously vac retard carb all you have to do is drill and port it. Large performance increase.
The ones I have are definitely vac advance. They are so old that they
have provisions for the metal pipe that screws onto the advance
diaphragm, and not a rubber hose (probably pre 1969).
That doesn't sound too hard. I'd definitely go that route rather than stay with the retarded dizzie.
Where do you drill it and what size do you drill it out to? I might have an old one myself, I'll have to dig around in my pile.
Dave, no I did not get any more junk, (the correct number is 6 decaying hulks BTW)...and I'm glad I didn't. Marc (Ground Up) got the '78 and my new Engineering Manager got the '72.
