My 79 to 75 bed conversion
Anchorage, AK
Hi all. Someone requested that I do a separate thread on my bed conversion--79 bed to a 75 bed.
Wanted to move the spare tire mount so had to weld new nuts. These braces on the front piece of the bed are NOT spaces evenly :-( You can see where I welded the new nuts by the dark spots towards the left when looking at the pic looking at the outside of the front cross piece. In the other pic you can see the spot where the original spare tire mount was located.
instead if cutting the box,i just move the rear axle back on my hzj75.
I just thought a bit more about what you said. That would not work because the extra 4in. was put on the front of the bed. To use a 79 bed on a 75 without cutting the bed you would need to cut and move the bed mounts back about 4in. and then also move rear axle back to fit. Or am I wrong?
Finally found this thread... I don’t understand your comment about the 19 1/4 block.
