Build My 55 project.
Cool thanks.
I posted up :D
Cool :D
Just let me know :D
Well I hope this is the cure to my running hot.It would get really hot while driving,but cool off if I stopped.I had two huge dead areas on the shroud so I punched 8 3" holes in in it.The idea with the rubber flaps is that they blow open while your moving,and then shut when your still and the fans are on.
And something else on the to do list,new wheels thanks to freds40 :bounce:
Yep :D The paint on the centers came off easy with the bead blaster.I dont know what type of coating was on the outer but it was a mofo to git off.I couldnt blast it off so I used some super dooper paint stripper .The first ring I did took 2 hours of brushing it on to get it all off.But it took 4 hours a piece on the other three.What was left I blasted off.It too for ever :hillbilly:
Came out cool lookin though.Same silver as my trim and my bumpers when I get them painted.
Thanks alot :bounce:
Dodge Viper fans have flaps like that
Yeah the military always puts A LOT of coats of paint on them. Of all the sets I've run I think I only took the time to strip 1 set all the way down because it was such a pain.
Glad they work for ya.
Now that I have started I have to finish.Had I have known I would have left them alone and just ran them :D
Is that a FJC fender behind the Irok .. ?
Why yes it is .Its the wifes.She says I can do whatever I want to it as long as I dont put any scratches you can see.It has alot of scratches underneath :grinpimp:
I sure hope it helps.Running Water Wetter helps alot,but I need just a little bit more to get the temps down :D
I cant run a Taurus fan.I dont have enough room between my rad and water pump pulley.Noel has one hangin on the wall and I tried to fit it in last summer :D
No,why :flipoff2:
I am pretty glad I kept the roof and doors.I was toasty even with no heat ;p
