If it sputters and dies like it's not getting gas, you may have a vapor lock. Burn thru your tank of alcoholed gas and try non-ethanol. Alcohol vaporizes earlier than petroleum gas. Worked for me.
An over heating coil can feel like running out of gas.Is this ignition module specific to a DUI dizzy? I have a similar engine shut off problem from time to time where after the engine gets up to temp (30 mins) it will shut off. I have to pull over and open the hood to let the heat dissipate and then it starts back up. I'm running this dizzy: Complete Mel's Electronic Non-USA Distributor - JTOutfitters
Just a wild guess...but, take off your gas cap and drive around and see if the problem goes away. Perhaps it is not venting properly and when the vacuum builds up, the fuel supply gets choked off?
Yes, I actually called and spoke with Mel at JT Outfitters about this specifically and he personally sent me a coil (his modified Pertronix coil) and guaranteed it was not the coil overheating. I spoke with him for about 45 minutes as he was an absolute wealth of knowledge.
Can you explain why he needs to "modify" an existing coil ? I am still using the coil from 1969, with a pertronix, and I live in Arizona with huge heat.
My coil story from another project. PCM ford 351 boat motor. Two new coils, both would not fire when they got real hot. Found out that PCM started getting cheapo chinese coils that were oil filled and really not designed to be mounted sideways. Bought an Accel epoxy filled coiled designed to be mounted sideways and never had another problem. Diagnosed by checking for spark when it wouldnt start.
Sometimes you cant trust new parts.
You could possibly have trash in your tank that plugs the pick-up and then when the suction breaks it releases and will repeat again later. I had this happen the rubber hose that connects the filler neck to the tank disintegrated and was flaking off rubber plugging the pick-up
JP
we need your date of birth as well.....June of 1977. All original minus smog delete, Webber carb, and a DUI distributor.
Good advice. The first thing I would check are the basics and go from there. BTW, I have found that owning a 40 is a life long chase of gremlins--especially electrical which Mark had noted in in a post in another thread.
When I bought my 40, I had the orig. carb rebuilt. I would consider that If I were you. At a minimum that process will get your carb cleaned and you can eliminate one source of potential problems. Sounds like fuel starvation to me btw.
