Much Caster ?
Panamá
Website
www.4x4panama.com
Hi all folks ..
Well finaly the bug can do better than me and I lifted my 80 series .. :eek: for my wife cheap deal in old coils .. :D
Anycase .. the damn it's huge coz I haven't yet anything more than stock weight in front .. so I'm thinking in the Slee 3º caster bushings or the caster plates .. ( OME are out of the game )
Due to the hard work to proper fit the caster bushings and coz I'm now around 4" lifted I thought in caster plates. I know it gonna drop down a little bit with bumper and winch .. but it don't necesary gonna hapen soon .. ( at least not this year )
I'm running right now worn out 285 but thing in 315 for Christmas ..
It's a big deal run with much caster .. ? more than 4º for example .?
thanks all .. comments are higly apreciated ..
if you are certain about the amount of lift you have then the best solution is going to be plates. Depending on how much weight you add you would need to drop the height by an inch before you started getting over 4*, so you should be safe. You might also need a DC Shaft to quiet the drive train.
With one of my templates, aligning the bushings is real easy and fool proof, but you will need a press for that.
Apart of the work on the arm to fit the bushings my only concern it's about to much caster when I add in the future weight in front ..
Other option coul be the slee caster bushings .. ( BTW are cheap than caster plates .. )
Thanks for your reply Landtank ..
Tapage,
Glad you started this thread since I'm on the same boat with you. I'm about to install an OME 850J springs and N73L shocks up front (863/N74E rear) and I know I'm going to get at least 3 inches of lift on the front. I'm also thinking to install the blue bushing from Slee and order the template from Landtank to make the installation a lot easier. I also have a winch bumper but no winch yet and dual batts install is coming soon. I'm not sure but I think the blue bushing should be enough to correct the caster once the truck gets a heavier load up front.
I would place a winch, bumper and double bat setup maybe next year .. it means with luck december next year .. it means at least on year with front pretty high. That's the reason what I'm thinking in get good caster now and mayeb for a year ..
But after a year what .. un weld the caster plates and do slee bushings . ? naaaaa
All comments are highly apreciated ..
Toy350 installed my plates on his truck with 850Js and ended up with only 2.5* of caster. My plates provide an effective correction value of about 4.5*. Slee blue bushings provide and effective correction of 3*
Toy350 would have to add enough weight to drop the front of his truck by an inch before he would begin to go over the 4* spec. Maybe he could take some measurements and add some weight to help get an idea what it would take to get that inch of compression.
Just some data to help you guys sort this thing out. And I assume Slee's caster plates provide similar correction as mine but I'm not sure and don't remember if any hard data on that has been posted.
Tapage, do you know which OME coils you put on it? Medium, Heavy, Extra Heavy?
850J and 863J
Just wondering if anyone drive 80 series with more than 4º caster .?
I would take a pic and post here .. to figure how much lift I have :D
Heavy Js. Okay, I have regular Heavies--850s on the front of mine with a winch bumper, no winch, no dual batts. I used Landtank's plates and got my caster back to about 3*. I'm thinking that even after I add a winch and batteries, and drop the front end, I'll still be at about 4*.
My point is, you may not even have to face the issue you're asking about. If you correct back to about 3* right now, after you add weight, you still might be right at the upper end of the specified caster range instead of over it. There's something on here about how much caster changes per amount of height changed. That'd be a good starting point.
Oh yeah--from other things I've read on here, it seems that having a little over 4* is no big deal--the steering might just feel a little heavier, I think?
Someone else should corroborate the greater than 4* caster info, though. That was stated from an imperfect memory.
Oh yeah--do you know what your caster is right now, after the lift with no correction?
No measurement of my caster right now .. But I " feel " barely positive .. maybe in the negative line ..
1.7º - 2º per inch of lift ..
pics ...
285 btw ..
Anycase still plans for 315 in christmas ..
You know, I don't think you'll get that caster right. You'd better just ship it up here and I'll worry about it. :D Might take a few years to figure out. In fact, I'm willing to swap you my truck as a loaner. :D
With my rig, I was negative with the regular 850s so I'd bet you are, too, with the Js. Your best bet would be to get a caster sweep now to see how much correction you need to get back in spec. Perhaps you could aim for the low end of spec--say, 2*, and then _hope_ the added weight will pull it to 4*? Not sure how much I like the "hope" part.
Does that sound feasible or is there a problem with that train of thought? Landtank? Any other more edumacated caster gurus?
I will pipe in, since I am running J's with no weight on front or rear. I netted 4" of lift with my suspension upgrade. I went for the blue bushings, and now I am getting the plates installed because after the bushings I was only at +.05. I might advise to cut to the chase and do it right the first time. Landtank's advice is good.
Jah, es ist sehr gute. I had OME bushings on mine and replaced them with Landtank's plates. Great results.
LOL .. send to me a pic of your 80 series ---> tapage@landcruiser.com.ve :D and let's see !
That's a great advice dude .. thanks .. I will PM to landtank anycase ..
I talk today with Christo ..
He said way much caster coul casuse dead wooble .. and I ask how much it's way much caster .. and he said could be 8º
Anycase I'm gonna do with Slee caster plates .. and see wha'ts happend. I'm expect 4.5º max 5º of caster ..
You should be fine. I doubt very much that you will be able to add enough weight to get the caster to 5*.
I read some thread from members that advice with J and no weight in front ( no other than factory one ) and no caster correction are in the -1.5º caster .. so 4º with the caster plates will put me back in the 2.5º - 3º in my mind off course ..
Wish me luck ! :D
Hi mates ..
Last saturday I was working in the instalation of caster plates, totaly pain less BTW ... only few mins cutting the brakets .. and all the rest come easy ..
After casterplates I was in the dark side of negative caster .. after I'm on the positive caster side with 3º + in both sides ..
The steering it's back on to this nice feeling ..
3 deg bushes give 2.7 degrees of castor correction normally, on a cruiser, and slotting the holes on the front can add more, leaving standard bsuhes in the rear of the front arm to help keep the steering rod away from the control arms, and fitting a 3 deg bush to the front, and slotting the holes can also help.
We aim for 3 deg minimum castor when setting them up here.
If running 35's or more we also aim for 1 deg neg camber.
