Most cost effective Power steering options?
Tucson, AZ
I have a 1974 FJ40 with a 2F motor. After driving a friends with power steering it's clear to me that and front disks are the two things I want done on my rig. So what's the most cost effective option I have? I see the brackets on eBay saying I can just bolt on a Toyota Truck PS pump. DO any of you have any links or ideas you can share?
I spent about $250 on my power steering conversion not including the donor engine I used to steal all the front engine parts off of to update my F, you shouldn't need any of that stuff if you are setup with a 2 pulley system. $100 of that cost is wound up in a u-joint from flaming river cause I couldn't find anything in a junk yard that would work.
I got a 3 bolt 4 turn box out of an 80s XJ. I also took its pitmit arm as it had the right drop and hole for the right TRE. I also took its hoses which fit perfectly under the cowl of my fj40 and was the right length to reach my pump. Pump was out of a AMC eagle and I mounted it to an FJ smog pump mount and fabbed a tensioner arm for it. I also got the steering shaft out of that XJ, I just lengthened it using a piece of tube that was the same diameter. I has a slip shaft so it is safe and the u-join on the end mounts to the box, obviously :D I got the whole lot from the junk yard for like $60 or 80. I fabbed my own mounts and frame reinforcements from .25" plate.
easiest setup is to use Bill Dorry's minitruck toyota gearbox bracket and saginaw pump bracket.
All of it is bolt on, requires no hard to find parts.
Total cost will end up $350-450 most likely
search for 'wdorry" there are several threads concerning his brackets.
I am running them on my rig.
I used a 79-85 mini truck gear box and 1985 Toyta Tercell pump. You also need a new steering box mounting bracket that will have to be made (there are some offered out there). You could also use an FJ60 pump and pump bracket if you can find one. My whole set-up cost me about $150 but I dug up all of the parts. I have been running this set-up with 35's for a few years with no problem. Not Saganaw but helps a ton. Oh, run a cooler too!
Good luck,
Hey Mate,
Never did see these brackets on eBay... But am interested in mounting an FJ60 pump to a pre '79 block.
Mind pointing me towards that auction?
TIA,
I want power steering for my HJ-45 and will be swapping out the stock H diesel drivetrain and dropping in a 1KZ-TE drivetrain. It will already have an AC compressor and PS pump; therefore, I have a good beginning to build upon. The problem I am having is that the truck is right-hand-drive and I can't use the usual solutions. Whatever I use for a PS box has got to come off of a right-hand-drive truck--be it mini truck, cruiser, or whatever. So I have been stymied for a while on this one. Also, if I source a right-hand-drive mini truck PS box, I can't use the conversion pedestals that are found so commonly, so I'll have to fabricate a mirror image version. I think the result will be worth the effort, but my work is definitely cut out for me.
Pablo, I think our new sonoran comerade is just confusing pump and box mounts. :doh: I didn't see any pump mounts like that either.
dieseldog, I feel your pain. I have similar plans for my HJ if I keep it. I was thinking that if if you took a standard issue steering box that has the pitman arm pointing forward and mounted that box further forward, with the pitman arm facing back, that it would swing in the opposite direction for the same steering column rotation.
Maybe that's over-simplistic, but an FJ60 box fits that description, so I'm picturing it mounted passenger side, inboard of the frame, ala Saginaw on a LHD.
You could start a separate thread on this on the 45 forum. :)
I know this is really redneck, but have you thought about putting another brace in the front that will support another member to mount the box too?
Mark and Diesel dog.. Just an idea.. But Hear me out..
I know there are saginaw style boxes that mount on the other side of the frame. I'd go that direction.. I accidentally put a ford Saginaw box on mine once (learning curve) and my truck steered backwards for a bit.. Or maybe a scout style box put on the pass side FJ60 style?
Good news: It looks like the half-cut I'm buying will have everything I need. RHD 1KZ-TE with a slushbox and transfer, 12volt (like my truck), Factory AC and PS so I'll have the pump AND box I need. I should be able to weld up a mirror image mounting unit for the box and go from there. I'll use the AC compressor and modify the hi and lo lines I already have with the system I've got in my 45. This is gonna be SWEET! Seems like the only technical problem I'll have will be in taking off the mini-truck transfer it comes with and putting on the one I've got here at the house (I bought a bellhousing/5speed/vacuum transfer all from a KZJ-70 from the UK. I'm hoping the transfer I have will readily replace the transfer that will be behind the slushbox on the half-cut. Soliciting ideas here . . . .
Note: The half-cut is coming off a JDM HiLux so the transfer is going to have the usual center rear output which is NOT gonna be useful for my 45 FF rear axle with offset rear pumpkin.
It'd work great with a toybox!
Roger that, I think so too.
Bummer, I think Doug S. was on his way to building some brackets, but that stalled when he rolled his 40...
