More wheel help
I'm having my 40 stretched and lifted a bit to fit 38's (currently running 35's with an SOA). I'm also addressing the stress issues related to larger tires (longfields, polyperformance rear, larger knuckles, new steering components, etc.) so that's not an issue.
The tires that I want to run are the Toyo Open Country MT's in the 38x14.50x16 size. I've read a ton of info on 15" wheels, but little on 16" wheels. What backspacing should be used? What clearance issues do I need to worry about? Any problems with using 16" wheels?
I have the stock front discs in my 78.
Thanks,
John
figure out how far you want them to stick out or in and that will give you an idea for bs, i like 2 or 2.5 backspacing, gives you a wider stance and looks good too. you should be fine with 16' wheels
