Modifications and powerplant change?
Southern Oregon
I'm slowly putting together plans to modify two stock 1997 Landcruisers to be used primarily as expedition vehicles in the northwest, Canada, Alaska - something akin to the Arctic trucks. I'm not a seasoned mechanic but do have a lot of outdoor survival experience, and a fair amount of mechanical/welding experience - but now I'm taking over more of the transportation issues - and I could use advice. I won't be doing the work though, the trucks will be shipped out to a builder - yet to be decided on once the funding is finalized. Both trucks will need to be able to tow rather heavy off-road trailers in addition to their own loads - through very bad weather. My question is, will engine performance be an issue - enough to consider changing out the powerplants? If so, (and I have no idea about this), what could be put in place? A tundra 5.7L V8?? If so, maybe it would just be better to get Tundras and skip the cruisers - ? I don't know, but would appreciate others experience in similar environments. Thanks!
Hmmmmm...Scratching my head. Seems diesel conversion may be in order? I know a handful of dudes on here have done the swap, one in particular with a 350?
I agree, Diesel seems to be more of a viable option when gas stations are rarely seen around each block...
Or, just buy a diesel Landcruiser(s); you can get them in Canada. The flip side if you keep the stock gasoline engines would be to add aux fuel tanks. One thought; start a new thread titled; "Help from Canadians and Alaskans needed" and ask your gas vs diesel question. There are a bunch of mudders from up north who would I'm sure have some good advice. You could also search around to find some with Canadian addresses ( ie: Edmunton,BC, etc.) One Canadian that comes to mind is Squash who works in a mine in Canada, part of his job apparently is servicing Landcruisers.; you could send him a PM (private message).
Good luck
How heavy are these off-road trailers expected to be?
If 5,000# or less then then a stock 1FZ-FE will be fine. These engines put out a lot of torque and many are towing off-road trailers loaded with RTT and expedition gear. Several guys also have relatively large camping trailers that might be the same weight that you are planning.
In my opinion, an engine swap; diseasel, SBC, or other is a big & spendy project and unnecessary for your purposes unless you are towing a trailer in the 10,000# range. The diesel Cruisers available in Canada are RHD imports from Japan. Their HP and torque are less than the 1FZ-FE with only slightly better fuel economy and virtually zero parts availability in North America.
With some searching and waiting you might be able to turn up a used S/C if you find that you need more power. If you are certain you will want more power then look in to the AVO turbo-kit from Slee Off-road. You might have to change platforms to the 100-Series to get that much power. I see the Slee web site only shows fitment for the V8 but give Christo a call and see if he is doing one on the I6.
-B-
Thanks for those replies...
I appreciate the responses. Thanks very much.
1. The trailer weight should certainly be less than 5ooo lbs, more like 2000 per trailer (as I'm adding up items and their weights) but I was worried about the terrain to be traversed. Well anyway. I want to avoid having potential difficulty obtaining parts, and will likely bring along certain items that may likely fail and need replacing.
Neuroguy,
there is also a diesel and an expedition forum here on mud; they also may have some suggestions. Many of the diesel owners who come on the forum are from Canada, so should have some first hand experience on what it takes to survive in Mountie country if that is where you're headed.
Neuroguy,
Avoid mounties with tazers:eek:
I'm curious which engine is better overall for extreme cold weather conditions, the 1FZ or one of the Toyota diesels. I know diesels seems to have issues even in mildly freezing conditions. Do those issues get worse, or are there remedies that pretty much solve those problems. I ask, because it seems like all the rigs in North Canada and Iceland, etc, are diesel. But I wonder if a gas engine would be better or not?
One of the major benefits of the Land Cruiser, is it's reliability. I would not pursue a major modification of the powertrain for the situation you describe. The 80 should handle a light trailer like you describe, without much issue. If you want a diesel, get a factory JDM rig (along with common spare parts), otherwise stick with a stock powertrain 93+ north american 80 series.
Beat me to it....diesel is the correct option. I would tell you to get a diesel truck (which is probably the best option), but I love to see diesel cruisers! Especially diesel project fzj80 cruisers!
4bt option, parts should be easier to get if they are needed, better fuel efficiency, and hp can be bumped up considerably. (intercooled, P7100, injectors, turbo) NV4500 tranny would suffice just be sure to upgrade the 5th gear shaft/nut/gear thing, but if something happens you just lose overdrive. In middle of nowhere I prefer to have simple and mechanical that wont need a computer to diagnose.
Motor swaps are not for people that are not mechanical. Leave it stock as suggested above. That is your best bet. A gas powered 80 will drag a 2000lb trailer anywhere. It might not go fast, but it will go.
So, you're planning to use the trucks for the job they were designed for. No problem. Get some tires under it that will handle the terrain and get expeditioning!
-Spike
