normaly:
1:the original bolt is crimped in the base of the turn signal , but easy to remove
2: it's impossible to remove the two connection without cut the two electrical wires ( problem of diameter)
this new bolt has the same outside diameter and the same thread metric , but a bigger hole inside , with this bigger hole the two wire with their connection can pass throught
there is two nuts , the fine nut is for assembly the turn signal (remplace the crimped), he is short because very no much place for assembly the turn signal base , the second longer nut is for assembly the turn signal on the fender
important :all the news part are made of stainless steel
