Mixing grease?
Hoschton,GA
I am in the process of replacing the rotors on my FZJ80 and I found something puzzling. The FSM says to pack the hub and the wheel bearings with the red MP grease, So I would expect the whole hub, adjusting nut and locking nut to be covered with red grease. When I cracked the front hub flange off all the grease I saw was blackish which is what I would expect Moly grease to look like. The outer bearing look covered in the black grease and its hard to tell if it was packed with the red. The Inner bearing has been packed with the red MP and the hub is packed with the red MP. There is some small amounts of the black grease in the hub as well, but I think that is more transfer than purposed packing. This is the first time I have torn an 80 apart. I have read all the posts on front end builds but I don't remember any references to 2 different greases in the hub. Any one out there with any insight?
Thanks,
Rob
I just swapped over to all moly for both birf, hub, and bearing. The stuff just seems to mix anyways. Couple mudders have done the same with documented miles and no issues. Just make sure to use the highest quality moly grease. The key to keeping the bearings like new is to pack them often. Never let the knuckle housing go dry or low.
I just found this exact same thing on my cruiser. The passenger side was red all the way with no hint of dark or black grease. The drivers side had dark grease on the outer bearing with red grease in the hub mixed with the darker colored grease and the inner bearing was mostly red.Could it be the PO had done some brake or being work recently but didn't touch the driver side? Do I have a failed axle seal? There was also some wear on the axle spindle...
Some people just pack more grease into stuff without cleaning out the old. Some greases are not compatible, can create problems if you mix greases of different bases but seems like most greases you'll find in the parts store are a lithium soap based grease anyway so whatever.
I'd just clean everything out and use whatever grease you want to run. Trace amounts aren't going to be a problem, it doesn't need to be spotless, just wipe everything out and then pack your bearings with new grease, and fill your hub full of grease and go.
Thank you Maxamillion. How does the wear on the spindle look?
Hard for me to say for sure but looks a little rough. Looks like towards the outer edge you have quite a bit of wear, to the point there a lip. I'd probably just put it all back together and set the preload a little on the tight side and see what happens but that's just me.
I'll let some other folks weigh in.
IDK I can't tell if there's significant wear or if it's just a little surface galling and thats just a line, not a lip.
If theres a lip... I'd think it'll probably need replaced. If it's just a little scuffed up, I'd maybe clean it up with emory cloth and run it.
Thanks! I can tell you that on the back side of the spindle, for the outer bearing there is a lip I can catch a finger nail on. The inner bearing surface damage is not perceptible to the touch and seems to be only surface corrosion/wear.
Ehh, it almost looks like a big step. I think some would tell you to replace it based off that picture and what you've said but I don't like to be loose with other peoples money so... is it just a little lip, like you can barely snag it with your fingernail or is there a significant lip and significant wear?
Clean up your outer bearing and place it on the spindle, does it seat snug?
Use your best judgement...
yea...my gut says to replace it, but my wallet says meh let's see what people have to say :D
Looks pretty bad, but could just be the picture. Looks like a large lip can you measure the surface behind the lip and the bad spot and see what the difference is? I would probably replace it, just because I wouldn't want to get it all back together and not be able to tighten the play out. But if you say it is just barely enough to catch your fingernail on, you could smooth it out with emory cloth and hope for the best.
It looks to me that water has gotten inside the hub. The grease looks like it has rust in it.
You can try to "fix" the spindle. Get a sharp point on a punch and make a bunch of dimples in the spindle on the top and bottom in the areas where the spinning bearing has worn a stepped down groove. Next get a new bearing and some Emory cloth sandpaper. Using the new bearing, it should not slide on to the spindle because all the rows of dimples have raised the metal up. Now take the Emory cloth and sand down the dimples until the new bearing will just slide onto the spindle. If you make enough dimples, and preload the bearings correctly, the fix will work for many miles. My rear spindle has this fix for over 60k miles so far.
Moly grease is sticky and is designed for CV joints and our birfields. The thinner red grease is designed for roller bearings like our wheel bearings. The main difference is a roller bearing needs to "roll" 360 degrees as it travels around the race. The thinner grease allows it roll and carry lube around with it. The sticky moly grease has moly in it which are very small sheets of a soft compound. The sheets of moly are great for high pressure and slower speeds because it does not get squished out at the point of contact. ie. the contact spot of a ball and housing in a CV (birfield) joint. Those same sheets of moly can cause the roller bearing to not turn and actually "skid" instead of turn while trying to roll around the race. This will cause a flat spot on the small roller to develop. No bueno!
The pressures are different too. Think about contact area of the 6 balls inside the birfield and compare that contact surface area to the 40 or so long rollers of the inner and outer bearings rolling on their races. A correctly preloaded roller bearing evenly distributes the pressure around the entire circle of the race at all times, meaning significantly less pressure at the contact points. Muy bueno!
Long winded explanation to why you need to use two types of grease. They are in two very different environments.
Thanks to everyone who chimed in. I think I'm going to replace the spindle and the seals and both wheel bearings and call it a day.
While I appreciate el hobmbre's post, I'm gonna go ahead and say that moly greases under say ~ 5% are fine for tapered roller bearings, they won't skid.
Just to clarify, by mixing greases I thought initially that a seal had failed which was allowing moly grease from the birfield to travel past the spines to mix with the red MP bearing grease. It sounds like this isn't the case but i'm changing the spindle, both bearings and the seals and gaskets.
