Build Mission Impossible......My 74 & 76 Build up by a Top Gun Land Cruiser builder :)
Member Build Threads
so I got s*** getting through 2 filters, going through a brand new fuel pump and getting in to another filter right before carb.... 2nd set of filters in 700 miles.....
so either I got s*** in the tank that looks like coffee grounds... or the rubber hoses are consuming themselves??????
Are any of the rubber lines in the fuel system original or is everything new? Did you install all new hard lines or are those original to the truck also? If the "coffee grounds" are black then it is probably bits of deteriorated hose.
all rubber lines are new... took all hard lines out.....
If all the new rubber lines you put in are "fuel hose" and not generic rubber hose I would contact the vendor / manufacturer about a possible defective product. The only other thing I can think of is you bought gas that was contaminated with whatever the "coffee grind" crap is.
they are all fuel line grade hoses, I have bought a different brand that I was going to install tonight along with new filters... if it is the hose then why is there more junk in the first filter, less in the second filter... and hardly any in the third... seems the longest hose run would have the most junk in it... so that should be #2... I got a brand new white bucket... we will see what is in the gas tank in about 1 hour... I got about a quarter of a tank in there now...
cant be gas... it has gone through 4-5 tanks of gas and from at least 2 different stations..
It's hard to believe that "coffee ground" size dirt is getting through one filter, then another, etc. I think you're on to someting with the rubber hoses.
Pull one of those off and split it with a blade. What does the inside look like? I wouldnt' be surprised if its deteriorating.
Do you have ethanol in the gas in your area?
How long was your tank stored before you filled it up the first time?
few months I suppose... never took it out of the original toyota box until I painted it a week or so before I installed it
we do in most of it... but I have been only running non oxygenated (spelling) gas with no ethanol in it....
Last night I spent a lot of time working on fuel lines…. I drained all the old gas and there was some “coffee grounds” s*** in it…. Not tons but some… I ran all new rubber lines, changed all filters and also bent up hard steel lines to go from the tank to below the tub. I have had problems before with the gas lines kinking so since I was here I bent all them up… pretty basic just some 90 degree bends. I am going to drain the tank again before the end of the summer… at least once maybe more…. Run some more gas through it and next time I am close to empty I will drain it again…
Since I had it on the lift I changed the oil and filter also… about 700 or so miles on that oil, since I only changed once after break in I only really wanted to do 500 on that second oil, but it was still so clean I ran it, probably did not need at all to be changed even now, but now I will to on regular oil change intervals.
Got some gas and took it for a ride, no problems last night… did not miss a beat… I am heading north this weekend for my family reunion… depending on the LC to make it all weekend as I am taking it up there…. Pretty excited… it will be my first only LC weekend where it HAS to work to get me home… Steve is in the area… did not get to see him last night or probably not tonight since I am leaving right after work, but him and supposedly Teddy and maybe even pete and their jeeps are going to meet up at my cabin from breakfast with my family tomorrow… so who knows what kind of trouble we could get ourselves in…..
Have a nice weekend…..
Sorry no pics… my dad borrowed my 4runner and camera is in there… bastard!!! :flipoff2:
I have bought fuel line that cracked/split/took a s*** in a matter of 2-3 garaged months.:mad:
On Monday I was driving the LC to work so I went out side to let it warm up in the shop before I left… I reached in and turned on the key… I forgot to check to see if it was in neutral and the ebrake pulled… I was in a hurry and did not… so it started up and almost ran over me… ripping my pants and shirt, and smashing in to the shop wall… it did some pretty good damage to the shop, nothing to the LC… nothing that can not be fixed but just a lot of work will be into this… It all happened so fast…. I just don’t really know what happened… glad I did not get hurt, minus a few bad bruises. The LC is not banged up so it could have been a lot worse…. The real bitch of it is, I was not drinking… which only goes to prove, I am 100% unable to function unless whiskey is involved…
ME: “Hey Steve is there a neutral safety switch I did not hook up for some reason???”
Steve: “This truck can not prevent you from killing yourself… maybe you should just give me the keys!!!”
Nicely done <<<<link
few pics from a few weeks ago.... had a great time driving around up by my cabin. getting ready for hunting season now, but got a few things in the works for the LC this winter... stay tuned.... I am not done yet...
just one more...... see you after hunting season!!!
So who was covering Cougar when you were show boating with this mig?
Seriously? Poser? There are two "o's" in GOOSE!
