EDIT:
**** it. I'm so tired of these idiots.
YOTA1 Performance in Riverbank Ca are the idiots with ZERO quality control. I spent tens of thousands on this bs workmanship knowing I was paying 30% more for the "experts."
TLDR: Shop forgot front oil drain plug, front axle is ****ed. What is going to need to be replaced?
So my LX450 was at a shop (supposed to be one of THE Landcruiser Shops in CA) for some other work (new engine), and they recommended replacing the passenger side knuckle seals as they had been leaking for awhile and they did need replacing. They did the work, replacing knuckle bearings and such as well. They cleaned and painted the parts. Looks great. So about the fourth hour driving after the repair while doing the shops recommended break-in procedure for the engine, I'm nearly home and start hearing something that sounded like a weird bearing wear issue. Immediately pulled over, couldn't hear anything from the engine. Get underneath and don't see anything obvious. The sound would happen when coasting, go away under any throttle. Was not engine RPM related, didn't change with brake application. So I feel I've ruled everything out engine wise, brake wise, and I'm, think my driveshaft CVs (or just U-joint? I dunno) are randomly going out. Sound was definitely more distinct in my neighborhood when there were cars next to me for the sound to bounce off.
Look underneath and see nothing, U-joint seem ok but hard to know. Inside rotor guard not rubbing anything, brakes look ok. I'm stumped so I leave it until this morning when I jack up the passenger side tire. I check for wheel play and it doesn't move at all. I feel there should be SOME play, but maybe rotor is holding it tight. I put trans in N, TC in N, and try to spin the tire. Its very difficult to turn. I crawl under and just stare at things for a bit wondering what could possible be wrong. I think, well, lets just put a finger where the drain plug is - ya know, just in case, no one could forget that. F ME. Nothin there. There's no oil on the underside of the axle housing or the vehicle. There has definitely been no puddles where I drove it. The only place it has been is Denny's on the way home, my home, and the smog shop, and it sat at every location for at least an hour to cool before I drove it for another hour. Not a drop of oil at any location from the axle. There is an oil line leak, that is enough to drip, but nothing else.
So what is likely to be toast after 4 hours with no oil? Axle bearing, carrier bearings? Differential (it is factory locked)? I had used the locker for about 50 feet on a dirt road while getting some engine time. Are ring and pinion likely toast? I'm dumb founded atm.
