- Thread starter
- #41
that's a great idea...much easier to reach than on the light itself. did you set it up so it works off one position on the lamp, or just straight wire it?
hijack off.
x2 - how did you wire it?
hijack off.
What I have found on my driver's door however is that the button on the outside of the door does not release the star wheel on the door to "spin" so you can ope the door. So I have taken to leaving the rear door unlocked, reaching in the DS rear door and opening the DS front door from the inside. Somewhat of a pain in the a$$ you might say!
Have people tweaked their door mechanisms to solve this problem?
If so, what worked? What didn't?
It was pretty easy- there is one red wire running from the light. I snipped it, and lengthened both parts of it so that each part would run to the switch location. then I connected both ends to my toggle switch, pulled the dash piece and mounted the switch there. (it was tricky because I only pulled the dash out a little - to avoid unhooking the heater controls. Then, I had to close the circuit on the light, I did that with a bit of solder to jump the little terminals inside the dome light. it was a little tricky because the plastic wanted to melt.
Very cool!
Question - could you have just turned the switch to the "On" position to skip soldering inside the dome light?
Well- yeah, but if your switch works, then you can skip the whole process![]()
Not seeing any answers, I opened up my drivers door and discovered that the stub connected to the outer door button has quite a gap before it reaches the metal plate surface inside the door to activate the release of the star wheel.
I was tempted to bend the plate closer to the outer part of the door, but not knowing what that mechanism looked like (or how easy it would be to break it) I opted instead to remove the outer door handle and run a few threads on the stub, thread a nut on a few turns (w/ loctite) and see if that additional length will unlatch the door drom the outside.
No pics.
I'll keep you all posted as to how it worked...
