mirrors without door
try searching google
Merci pour votre réponse, mais celle de Toyota est chromée. Je ne veux pas de chrome sur mon BJ.
The previous owner of my 40 installed these heep mirrors. Drilled and tapped into the windshield hinges. I added the Toyota mirrors onto the arms later. They work great, no vibrations while driving and fold out of the way when needed. It's the only P.O. modification I kept after all these years.
Super, is it welded or screwed?
If it is screwed it does not interfere with the sheet metal of the windshield bay?
Bolted to the lower part of the windshield hinge, the metal is fairly thick there. It does not interfere with the stock hinge bolts and I can still fold the windshield down.
Sorry I made a mistake. Under the hinge it is not empty, there is bodywork. How do the mirror mounting bolts interfere with it?
Too bad to buy new mirrors more than 200 € for repainting with a brush. The advantage is that one is sure of the quality
thank you for your answer but I live in France and between shipping and customs fees to buy the Toyota
I like the classic style, but not a $110+shipping- never mind the gold plated version SOR is selling. I need to save the funds for other projects...
Are these the mirrors you have? They look like they would fit the bill for what I need and wouldn't make me cringe as bad if a tree took them off.
For products in France, I’d start by contacting: Bienvenue chez Lekma Carrossier Constructeur - LEKMA - Landcruiser Metal Parts
I don’t see a listing on Fabian’s site, but I’d suspect they’ll have an idea where to get parts in France.
If all else fails, make a bracket for your current mirrors or mount them to tube/half doors. Here you can get hassled for no doors... although I haven’t yet. I find I prefer 1/2 over no doors... especially when it decides to rain on me.
So two nights ago, on the drive home, I found out the law would like me to have this taken care of- in the next 30 days. He was nice enough about it and asked some general questions about the “Jeep” build. So I went to google to find an answer that works for my needs- low profile, stout enough to take on a aspen branch or two and cheap enough not to worry about. There were some 40 options, but the prices were steep or the reviews were mixed at best. So I turned to the Heep aftermarket, looking for least fabrication I would need to do. The windshield hinge mount was the leading contender, until I found something similar to this from Outlaw Offroad:
So I went out to the scrap pile in search of material. This particular piece is from some cheap furniture- it had perfect ID with a slot to slip over the hinge. This is Version 1.0, it meets the basic requirements: cheap(scrap), simple, easy to remove, stout and out of the way. I did end up having to spend $30 on the mirror head, but I never liked the small convex mirror on my hard doors.
Things Ill change-
  1. It needs to bend out from the windshield a little more to see past the cage.
  2. It does vibrate a bit. This is likely do to the 35" MTs. It vibrates while idling at standstill more than at speed, so some of this will be there regardless. I'll try plastidip on the inside to help isolate the vibration.
  3. final paint will be pewter like the OEM arms.
  4. Something other than the hose clamp to snug it down. the tube needs to be thin walled to slip between the hinge and "rib", so I think a pinch nut wouldn't be effective. I'd love some suggestions on this point.
Hoe this is useful to someone.
