- Joined
- Aug 15, 2005
- Threads
- 776
- Messages
- 5,125
Mike (Sine80) came down this weekend to help me install a mini power steering. THANKS MIKE!
We should have known that we had it too easy making a bracket for the pump. The set up uses one belt. It seems there is enough contact to keep the water pump going, so that made things easier and I had a smog setup before so it was cake for the belt. It took about 30 minutes to get it installed. The trouble came when we started to install the box. Someone sent me a pm a while back and was positive that I could cut and gusset the stock mount and it would work. Well after about 2 hours of wasting our time, it sure as hell didn't work. If that dude is reading this, what type of crack were you smoking? So Mike and I took a moment and figured out that it would be easy enough to fab up my own mount. Thanks again to Mike for bringing down a sheet of 1/4 by 3x2 flat stock. So we made the mounts and figured out how to drill holes for the bolts. After bolting and unbolting the rag joint and steering wheel brackets, we finally got it looking right. By that time we were 9 hours or so into it so we called it a night. The next morning we were off to nasty AutoZone and the hardware store. Two trips back to the zone (and one more later to get a narrower hose); we were ready to bolt everything down. Quick bleeding of the system and looks good. I have a few minor ends to wrap up like cut a notch out of the bracket so the pitman can get full range of motion, install another thinner belt, and put the body back together. I am happy with the results after the test drive.
Thanks again Mike for the help. But, sucks that it started raining for the 2 hour drive home without a top. Bummer.
mechanic (me) a well-made bracket makes all the difference...
