Metal Tech Slider ?'s
Burque
Hello all, noob issue here.
I just received my new set of sliders and have finished installing the drivers side. Looking at it installed the front rub rail seems to be misaligned and not parallel. I'm not sure if this is intentional or not and they're not open to ask so I thought I'd post here. Measuring from the body, just behind the seam from the front fender to the center of the rail it's 2.75 inches and at the back before the tie in to the kickout it measures 3.25 inches. Viewing down the door sill the slider itself is parallel with the body and the kickout looks parallel, so it's not misaligned there. I haven't installed the passenger side to compare it with because I don't want to deal with them both if one is welded incorrectly. I viewed the write up on the sliders and its difficult to tell if they have the same angles as mine. Can anyone with these sliders confirm if this is correct or not? Thanks in advance.
Oh yea, first post on the "Big" forums so :flipoff2: away!!!
those sliderz are sicc...Let's see a pic of the whole enchilada...Oh yeah,:flipoff2:
Arent they supposed to be like that?
A gradual angle away from the body? It looks like there is a kickout near the rear, which would make sense to me. I would rather it be that way than directly parallel to the body so a rock you slide across doesn't slide off the end of the slider into your rear fender.
Zen,
IIRC the distance from the body to the slider tube (until you get to the kickout) is a constant distance. I'm attaching some pics of mine so you can see what mine look like and compare to how yours look. I haven't measured the actual distance between the body and slider tube to know how mine compare to yours though.
Possible the tube was welded in and incorrect position, Metal Tech changed the design a little?, or that your frame and body aren't as "square" as they should be :meh:
Call Mark in the morning and see what he says...I looked at the pics on their website but there weren't any real good close pics showing the relationship of the tube to the body.
When you do get to the PS w/ the cat guard. On mine after install the cats were touching the guard and created an annoying "rattle". I had to use some spacers (washers) on the top two cat guard bolts to space it down and away a little. My suggestion before you crank everything down tight is to see if it looks like your cats are going to be close to touching the guard and if they are, go ahead and put a couple washers on the bolts now rather than trying to do so after you've cranked everything down tight like I did :rolleyes:
Passenger side...
Is the actual slider parallel it the rocker panel seam? It should pretty much be. Now if the tubes aren't parallel too but the slider is, I'm guessing either the tube design changed or it wasn't welded correctly. Here are some pics when mine were installed by Mark and LT. Thanks again guys!
Front Drivers side:
Rear Drivers Side:
After further inspection, I rule improper angle before welding, flag on the play - 10 yard loss.
post up pics of the whole shea-bang Ive been thinking of trying to fab up something like the metal tech ones myself
Good luck, Metal Techs sliders are made from some custom bends to plate steel that make them different from other sliders using 2X3or4 square tube steel, lots of custom work goes into Marks design.
Cody,
There is a kickout that does protrude father than the front rub rail. The kick out section is parallel, but not the initial part. It's not as clear in the pics but in person it is very noticeable.
Thanks for the pics, the second one really shows the relationship from the body to the initial rub rail section. The frame/body relationship should be square enough because the slider itself runs parallel with the body. It's difficult to tell from my overhead angle pic, but it's nowhere near to running parallel like yours are.
Chad: I designed rub rail to be parallel with the top of the rear kick out. If the set you have is not, then it’s a simple matter of the welder placing them incorrectly prior to welding. The more unfortunate thing here is he did not catch his mistake and sent them on the way. I will say the same thing that I would have said last night at 9:30 PM when you posted we were not open to ask this question; we will happily replace the slider. Please contact us when it is convenient for you and we will send you a replacement at our expense.
We are actually in the process of setting up for another run of our FZJ80 sliders. This next run is going to be using a new fixture for aliening the rub rails for uniformity. So this physically could not happen again. It is just an unfortunate coincidence a set was built with the rail out of alignment. The primary reason for the new fixture, we are going to have a robot weld the next run. Everything must be dead on for robotic welding! We also are lowering the cat guard yet another ¼” for more clearance. We hate to give up ground clearance but with all the inconsistencies of the down pipes by Toyota we still occasionally get cats touching the guard. This will be eliminated.
Brian894x4: Chad had these on order for a while. Everyone that has pre-orders on file always get first ones available. Last run we did all were pre-sold. About half of our next run of our 95-97’s is also pre-sold, but we hope to once again put some on the shelf. We have a few sets of 93-94’s remaining in stock right now. By mid March we will have more of all our FZJ80 sliders in stock.
Mark
Mark
Mark, misalignment aside, your design and fab work is some of the best out there for our trucks. And :beer::clap: to you for excellent customer service again! Vendors like you make the world a happier place.:p
x2 - MT's customer service is awesome!! When I got my sliders for CM07 the trucking company was less than gentle on them during shipping and banged them up a bit. I was being overly picky/anal about my new beautiful sliders at the time :D but Mark took it in stride. Mark offered to bring a new set to CM, take mine off (after I put them to good use even), and put a new set on free of charge. Very generous and an above and beyond offer IMO for something that wasn't their fault! :beer:
x2 on MetalTech's customer service and design... I have never seen anybody spend so much time on the details. That does make it a little slower to get the product, but you will be getting the best out there. I think that Mark is happy to have me around so I can beat the wee-wee out of my truck and give him ideas... Then he ticks off his wife by playing with CAD drawings til 3 AM! :flipoff2:
X2 i have never met anyone that could stay up night after night until 3am but here is the kicker....get up and go to a different job at 7AM!?>!?!:eek:
if i did that once i would be worthless the rest of the week.
PS when you really start to look at the metal they used to make these sliders you will realize they definitely are in a different class...laser cut pieces and formed plate...very heavy duty
barrypt5
