Melted EGR Vacuum Modulator
North Jersey
After smelling some burning plastic I looked under the hood to find the
EGR modulator in an extremely melted condition and it even melted some of the hood insulation. All the hoses are connected none were loose. My question is can blocked, or melted cats be the cause of this? I've been lightly driving it since I replaced a dead #6 injector this summer that was causing the cats to glow cherry red. It was running fine when I first got it back together but now seems to lacking power so I'm guessing the cats are probably breaking down and getting clogged. Is there anything else that could cause this meltdown and at this point what else could I've have destroyed as well?
Thanks
Merry Christmas, Happy Holidays
I had this happen back in August
https://forum.ih8mud.com/threads/it...ive-had-an-mil-401-egr-code-revisited.660812/
Replaced it without issue and figured the bottom hose just came loose and slowly melted the plastic away with hot gases, but it happened about 2 weeks after my primary cat had failed, so now I'm thinking it probably blew off when the system got backed up due to the clog :hmm:
https://forum.ih8mud.com/threads/ha...-the-drive-home-temporary-overheating.813602/
I have since gutted both cats and have yet to throw a code, even after 15,000+ miles :cool:
Running better than ever at 382,xxx miles :grinpimp:
EGR stuck open. Are you sure you aren't getting any CEL codes? Also, having the EGR modulator non-functional will affect engine performance/power.
No codes at all but a very rich smelling exhaust, lack of power over 50 MPH, and poor fuel economy.
I think the cats are toast, dam shame they are OEM and were replaced in 09 I'm going to drive it too much until I can take the cats down to inspect them. I'm guessing the pressure vented out through the EGR.
Any problems passing state smog tests with cats hollowed out?
No smog in FL, but I hooked it up to the monitors at our shop here on the Island and it passed with ease :cool:
Not sure how it works in Jersey nowadays, but here in NY, as long as you have an OBD-2 car that doesn't throw a code, you pass :)
Next time I'm there, I'll hook up the sniffer and see what kinda numbers she puts out :hmm:
*sent from my android powered string cup*
I'm OBD-1 so I get the sniffer, it passed in July just after getting all back together and after sitting for about a year. It took the dunces at the state facility 10 minutes to find the cats with a mirror, flashlight and one guy under the truck looking as they are under the slider, but come on, duh! I asked them if they were looking for a bomb or contraband, and that confused them more. I don't really want to spend over $1200. for two new ones again, so it seems like I have other options ;)
Thanks
I have the same exact condition as you and am trying to get a plan together to attack this. Someone suggested that the EGR could be stuck open above but that seems like it would cause no start issues. Did it end up being your cats? And short-term, did you just replace the modulator and keep driving?
Replace the modulator.
The exhaust blows against a diaphragm in the modulator to regulate the vacuum signal to the egr. If the ecu doesn’t want the egr it opens the vsv to vent the signal the modulator created.
If you take a good one apart you will see a tiny black dot in the filter pad. That is a controlled exhaust leak(bleed), the distance the modulator is from the exhaust pipe that feeds the egr will dissipate the heat created from that control bleed.
When that diaphragm gets old it breaks down and leaks internally, letting to much exhaust flow through the modulator thus creating enough heat to melt.
Thanks for your response. I've had the truck 1.5 years and still enjoy learning every new system. I'm picking up and installing a new modulator today and hope that solves the problem.
Because I hope to own and enjoy it for another 20+ years I'll probably dig deeper soon. For the next couple weeks I just need to go 5-10 miles in the city. But I'd feel better knowing that the throttle body was cleaned and that the EGR Valve and VSV both work as they should. I'd also feel better knowing that excess exhaust pressure isn't going to cause this new $100 modulator to fail again. So gonna come up with a plan for that too.
Posting another data point - I replaced the modulator 11 months ago and last week I had the same thing happen again (melted like OP). I need to go back and re-learn about the EGR system because clearly something is wrong. Dealer is replacing the part under warranty but while chatting, they really don't think it's a symptom of excess exhaust pressure from failing/clogging cats (any ideas to test this would help). So I will probably go the route of opening/cleaning, replacing vac hoses, testing again, possibly changing the VSV even if it tests fine. What's the lifespan of the valve itself? When taking out the melted modulator, I thought I spied a little pinhole in the side but when I was doing the tests last fall, it worked fine and between replacing this expensive part and disabling the system, I'm definitely leaning towards the latter.
Just to follow up - I confirmed high backpressure (>10psi) via hole drilled between Y-pipe and first cat. I already went through and removed and cleaned the TB, put a bunch of new vac and fuel hoses, and replaced and rerouted the VSV. I've avoided melting the new Vacuum Modulator by limiting driving/rpm's but putting a plan together to replace the cat, likely with a single Magnaflow 99006HM.
@jatree any updates on this. I experienced the same.
Hi - Yes, I found a shop that was able to replace my two original catalytic converters and with a single magnaflow. There was some blockage in both -- problem has been solved since then, though I still have the patch of melted hood insulation as a reminder!
Another data point for the thread - I'm currently out on the road experiencing this issue. I thought my lack of performance was due to the added aerodynamic penalty of my new roof tent, but as I observed the beginning of this power loss before then I am now ruling that out.
I've had the P0401 code for all four years of owning this rig. I replaced the VSV when I first got it, then reverted to an old habit from my VW days - keep a code reader in the door pocket and fuse panel cover removed. In hindsight, I don't recommend this.
This was a big clue at 251k miles that something else was wrong today:
Have been running it hard on a road trip for a little over a week now and I think my Vacuum Modulator has called it quits.
The line on the bottom was missing entirely when I discovered the problem.
Oddly enough, P0401 has remained off for miles and miles while I limp the rig back home. Will be picking up a replacement at a dealer on the way back and will provide updates as they happen. I already have fresh hose ready to go in. Fingers crossed a few hrsprs come back.
Thanks to everybody else who has contributed to this thread, it's been very helpful.
What are you picking up a replacement of-modulator? Something else has got to be wrong, such as a bad EGR valve.
Having gone through a very similar loop -- check for exhaust blockage. My cats were clogged enough to melt the modulator. A backpressure test can tell you.
