Build Meet Ivy, 1976 FJ40 w/VW TDI, 2.8 CRD, OM606
A little update on the suspension. I think I have the front coil overs dialed in now. The springs that Accutune recommended seem to be spot on. Only had to adjust the ride height a little for side to side. With my home brew front radius arms my front suspension ended up being 1/4in higher than it was with the leaf springs. Really happy about that. And I have a full 5 in up and 5 in down travel. I may adjust the front down that 1/4 so it will end up the same as with leafs. Absolutely LOVE the way it rides now!!!! It does have a little body roll now. But that will be remedied when I do the coil overs in the rear as I will be adding a rear sway bar. My front bar may be a little soft for the coil overs. I am using a stock 60 series sway bar in the front.
I always had a rear squat with the rear Jeep coils, so for the summer I picked up a set of 1.5 in lift rear coils, I will get them in this week. Next winter I plan on changing over the rear to coil overs as well.
Does anyone know of a plug or block off plug for the speedometer drive in the back of the split case. My transmission has a speed output so I would like to block off the factory on in the split case.
Does your old one have a screw in section for the cable? Yes glue on a plastic cap. Or use it to make some sort of plug. Use silicon mold gel to make a mold around it. Then use a couple of tubes of JB Weld to cast a plug.
@sogncab and @charliemeyer007 Those are great ideas. Thanks for the brainstorming. I will take it apart and check it out.
Jason makes them. Order here:
Trail Tailor
Yes, great price for what looks to be a great solution. Making/fabing your own cures to a issues can be very rewarding, plus there may come a time when there is no store.
Well, I think it was the day after I took the pic above on June 15th that the Nag1 transmission gave up the ghost... But, I am glad to say I am back on the road again with a newer stronger transmission. An 8hp70 and wow am I impressed. So far this was a well worth upgrade. Shifts amazingly smooth and quick. Still have a little tuning to do but so far very impressed. Put over 100 miles on today running around Nemadji forest testing it out.
