Maximum tyre size?
Western Australia
Hi all
Im new to all that is FJ40, so this may be a stupid question.
Im wanting to know what the maximum width tyre I can run on my fj40 without using flaired guards, that wont rub on the body. They must fit within the outside edge of all the guards for legal reasons.
Any info is much appreciated. :)
Even a 10.5in will stick out a little (very little), enough to throw up mud and water onto your tub. Max is 9.5 if you truly want them inside the wells at rest. 11.5 can be run (for instance, 32X11.5) without rubbing at flex (they "tuck" as they flex) but at rest will stick out.
Yeah, 9.5 to be safe and anything larger will throw a lot of mud and water at you. Metric sizes in 16" wheels may give you more skinny profile options.
Good luck
Thanks very much for your replies :)
The car isnt lifted.....yet. I will do that later as cash becomes available, but tyres are required right away. Found the car in a yard with rotten tyres on it.
When I do lift it, Im going for a 4" lift.
Since you say tyres instead of the right way - tires - I'm betting you don't have access to the all the sizes we do here in the States, is that correct? I would recommend a BFG 33x9.5 AT, very good tire for stock trucks and should be easy and cheap to come by.
Good luck :beer:
I would recommend not getting that tire if you wheel the truck at low pressures.
What size wheel are you going to/want to run? What will the truck be used for?
just flare it.
get some plastic garden edging and some tech screws...
then you'll fit 33 x 12.5's (or 34 x10.5's) with minor rub on inside rear fender, and maybe rub at full lock turning left with some suspension flex on the tie rod ends (don't ask how i know that)
Pix please! :flipoff2:
I run 33x9.5 on my non-lifted 72' 40... nothing sticking out, great for the snow.
nah that's not how mine is done. mine is done with rubber and tech screws. before i knew about the garden edging.
i run 33x12.5 on my stock cruiser and it only rubs in extreme flex postions, or when i have alot of big people in the back. it doesnt stick out too much, but here in florida, that doesnt matter. you could get cheap flares in the back and be fine
Yes Im in Australia, so yeah we dont have the choice of tyres that americans have. The car will be used for commuting about 15 miles to work each day, with offroading almost every weekend. Not into rock crawling and all that, nor racing through mud to see if or when I will get stuck. Mostly gravel, with some powder sand thrown in for good measure. Just driving into some harsh country that doesnt get any traffic at all.
For on road and moderate off road, try the 33X9.5, smooth; does not require power steering, does not "follow" the ruts in the road or pull you around much, very comfy on road. Looks cool too. With a hard top you might want to consider a small shackle lift (2 in longer than stock equals one in lift) in the rear only; many 40s need help in the rear over time due to sag. Leave the front stock for now and you will have no steering/wander issues. Rear shackle lift should be very quick and easy; does not require re alignment either. They will fit within the wheel wells too. Try this size; I think you will be happy. Its what I run on one of my 40s.
