Max Tire Size
Charlotte, NC
What is the max tire i can put on a stock 1995 Land cruiser? I want to go bigger than the 275/70/16 that are on there.:bang:
if your not doing a lift I wouldnt go over 285, that gives you plenty of room for articulation, I ran 285 on mine for 2 monthes and never had any problem, however ive seen 315 on a stock cruiser, but I wouldnt do that, unless youre getting a lift
good luck
Please check the FAQ.
Which will tell you that 285's fit on a stock cruiser :flipoff2:
In Clintonesque...it depends on the meaning of "fit". I have 285's and have had no rub issues at all even in the rocks and without bumpstops. On the other hand, if you don't ever wheel off road, you can go up to a 35" w/o any rubbing issues. Gearing on the other hand will need to be changed for better drivability with 35's. Search around and you'll see someone who recently put on 37's w/o a lift.
Cody is running 39" Michelin XMLs with no problems. That is what you need. :bang:
-B-
What is the conversion from metric to us units for 285?
315/75R16 ~35"
305/70R16 ~33"
285/75R16 ~33"
stock ~31"
You really should consider searching though. Lotsa great information available along with all the opinions that are forthcoming.
-B-
Tire size calculator
tire calculator site, tons on the interweb if you search:flipoff2:
I got mine w/ 305/70/16 and no problems, almost same dia as a 285/75/16 just fatter.
305/70/16 BFG MT's with sagging springs and a trailer without any signs of rubbing :)
If you are not rubbing your 285's then you are not wheeling hard enough and probably don't need a tire that size. 285's will rub with a lift. Actually I imagine 285 with a 2.5" lift and stock bumpstops might rub more in certain situations than stock hight because the additional droop of the extended wheel will lever the completely stuffed tire at a greater angle causing it to rub the inner fender.
wow. 35's! i had no idea that would fit. What is the conversion from metric to us units for 285?
Yup. Stock height 1991. My truck, but not my tires, FYI.
Major rubbage while turning left, though.
I have aftermarket wheels too, which might be why mine don't rub. No problems here with not wheeling it hard enough, body damage proves that one:doh:
I definitely am not the most hard core wheeler (and I dont have the body damage to prove it) But I do have stock wheels with out spacers. I would rather have more travel at the expense of extremely minimal rubbing than add bumpstops.
328/85/16...but it will make funny noises as you try to drive and the tires start rolling.
Drive faster til the noises subside.
