Max engine temp?
Littleton, CO
I am wondering what the safe max engine operating temp is before the engine should be shut down or vehicle stopped and allowed to idle under no load?
I did some searching and came across some interesting threads about the ABCs of cooling and what but nothing that answered my question and the FSM gives a bunch of information but I'm never sure if I am reading it correctly...
So, my question is what is the maximum safe operating temperature is?
A little background...We towed a 3500# popup camper from Denver to Moab and back for CM07. On the way out, going up Eisenhower and Vail Pass per my Scangauge II dealyo my max WT (water temp) reach ~215 degrees F. Speed was REAL slow and sometimes down to just 25 mph.
On the way back from Moab pulling Vail Pass and Eisenhower is even tougher because they are much more rapid, steep, long climbs going West to East. In each case speed was down to around 25 mph with rpms reaching 4000+ in 1st gear. It was during these climbs that I actually got to see my stock (non-modded) temp gauge go past horizontal and actually move. I estimate it got 2-3 needle widths above horizontal and per the Scangauge the max temp reached was225 degrees.
In my searches the only applicable numbers I could find were that 203 degrees seems to be the temp at which the cooling system is "balanced" (WOT) and that the AC will cutout at ~226 degrees (per CDan below).The AC wasn't on in my case as it was snowing and thus fairly cool (high 30s to low 40s) while driving up both passes...
TIA
In my searches the only applicable numbers I could find were that 203 degrees seems to be the temp at which the cooling system is "balanced" and that the AC will cutout at 230 degrees but not much more. AC wasn't on as it was snowing on both passes that that wasn't an issue...
TIA
The general consensus (buried in those threads) was that you should never go above 225f since Toyota felt that was the temperature at which to kill the A/C to preserve the engine. I know that with a proper functioning system, you really shouldn't see over 215f. Personally, I have not gotten over 210f and that was pushing full throttle third gear going up a one mile grade at 70mph on a 108F day.
I am concerned that you saw these temperatures on a snowing day. To me that says you either have a plugged radiator and/or bad thermostat. If your radiator has never been replaced it is 99% certain that it is at least partially plugged. I would also bet your fan clutch is bad. If it were me, I would invest the $500-600 and replace the radiator, thermostat and fan clutch before it gets hot out so you don't get stuck having to screw around with it and possibly overheat the truck on the first 80f day.
Cary,
Thanks for the info! I was starting to worry when I hit 215, then really worried when we hit 225. Normally the rig won't ever even hit that magic 203 temp driving around town in 80+ degree weather. Typically it seems to like 198 ish per the Scangauge II.
Outside temp was in the 40s (snow but roads were just wet) and the both the grades were very long, fairly steep, grades pulling the load. In the end we were down to ~25 in 1st gear pulling 4000 rpms. On similar drives on those same hills not pulling a load the temps remained in the 200 range but of course my speed was much higher (55 ish).
I don't plan to tow again for awhile so it will allow me the opportunity to look into the issue closer and get on some of those PM activities you mentioned. I like to do things once but that gets real expensive real quick...I need to replace the PHH but while I'm doing that I might as well service the starter and do a full cooling system flush...But, while doing that I might as well replace the TStat and radiator right? :eek: It just never seems to end
You fan clutch is definitely bad, but the radiator is probably also partially plugged. At 4000 rpms with those temps you should have clearly heard the fan howling.
There is no need to need to change the oil or tranny fluid as suggested by Jon. Even a good quality mineral oil is fine at those temperatures and the tranny fluid is on its own cooler. You will be able to tell if the tranny fluid was overheated, it will be a bit burned.
Thanks again Cary. Fluids were changed just prior to CM07 and both still look new (Mobil 1 oil and Valvoline Max Life ATF) so I think I am good there.
I will do the necessary checks on the fan clutch and address as necessary. On my old '99 Durango I could definitely tell when the fan kicked on (sound and significant power loss) so should I expect similar sensations on my LX when the fan kicks in? I don't but then again I'm not all that familiar with the 80 series yet :frown:
I've got a great club here though (Rising Sun) that is always willing to help a noob out :D
The simplest check of the fan clutch is to listen for the startup roar. When you start the truck, the fan should run full bore for about 30 seconds. If it doesn't, then the fan isn't working right. You've been here a while so I assume you know about Cdan.
Thanks...Well I don't think I've ever heard a "roar" :frown:. I thought the only reason Lexus put a tach in their rigs is so you knew the engine was running 'cuz they're suppose to be so quiet :D
As for Cdan...Yep, I've already fed his dogs once, apparently it might be time to do it again.
And I suppose you can check the motor oil by licking the dipstick?
No offence intended here but that is not sound advice IMO. He did heavy towing in less than ideal conditions with a questionable cooling system. Let's not forget that the tranny fluid also passes through the bottom of the radiator which would act as a re-heater in those conditions.
IMO a fluid change is free preventative maintenance, but it's not my rig so I really don't care. Do what you want.
FYI a fan clutch can fail in a variety of different ways. Hearing the startup roar of the fan doesn't mean it's good to go. It just means it's working properly when cold. They should be replaced every 100K miles with an OEM unit.
The oil temperature would have never gotten over 250F. Even modern Group II mineral oils can comfortably handle 250f for a while. He has already stated that he is running Mobil 1, a group IV synthetic. Unless he got the oil above 300f for a long while, it is not an issue. If he had gotten the oil that hot, he would be rebuilding the engine right now.
Since Mr T cuts out the A/C compressor at ~226F and allows it to come back on-line at ~217F, logic dictates that Toyota considers anything below ~217F to be "normal" and anything above ~226F to be too hot.
Thanks for the info Dan! Assuming the Scangauge II is providing accurate readings, then I was just about to the "hot" point. Scary when you consider the stock temp gauge was only 2-3 needle widths above horizontal where it seems to spend 99% of its life.
With only a 9F window between high normal and hot, I cringe at how fast the stock gauge must shoot up when a person exceeds hot and gets into :eek: territory.
Although the next time I tow the popup probably won't be till CM08, I'll probably be sending you an order for a couple of those fancy blue fans soon just for the piece of mind :)
umm, cary is the oil guru, I don't know if you realize this or not, but you are locking onto a losing battle here :)
