It does help some. From watching my amp meter closely, it looks like the output is pretty. Much topped up around 1600 rpm. I set my H T there whenever I am winching or running Puma to fill tires. John
I have used a hand throttle while winching to keep the RPMs around 1800 or so and I have done many recoveries with the truck sitting at idle. Since every recovery situation is different, I make it up as I go. Does it really make a difference? For short pulls, not at all. For extended winching sessions I would keep the RPMs up. A winch will continue to pull as long as there's enough current to keep the solenoids energized.Does a hand throttle help much in this department? I picked one up in anticipation of buying a winch and not wanting to go dual battery yet. I'm sure there are many threads but also seems relevant here : )
FYI, stereos and LED light bars and lights in general are not high load items. No other accessory will draw power like a winch. Have a look at the winch manufacturers websites and look at the 12 volt current draw charts.
