Matched Front and Rear lockers?
smf
vegas
I am wondering If I put a rear locker in do I need to add a front locker at the same time or can you just run the rear? I have not upgraded the Birf's and with 35's and locked in the front I know I will break down. What should I do?
You can definitely just run the rear if you want. I would not put a front locker in without a rear one, but a rear without a front is no problem. I have 36" tires, and a rear locker only, and have been that way for 7 years.
rear only would be fine, thats what im planning. i got an aussie locker e.t.a monday, im stoked
you should be pretty darn happy with the aussie...i've had one in the rear of my wagon for a year now and am very pleased...i just recently put on in the rear of my 40 also.
I 2nd a rear locker will amaze you. I found a rear locker and front true track posi to be a good combination for keeping birfs together in my mini truck, but I still broke them periodicaly. Can't get a truetrac for the LC though.
I also think the longs are money well spent, but not necessary without a front locker.
The great thing about Cruiser diffs is that you can swap them front to rear. With a little effort and gear oil, you can try out which setup you like best.
With one locker, my vote is definitely for the rear as it won't affect steering (as much) and the increased ability of your rig will astound you.
I had a rear locker for about a year, then pulled the whole diff to put into the front. Then I took the open front diff, welded it up, and put it in the rear. I got a good deal on my locker and did the welding myself, so I locked both ends for about $85 total.
I now have 'unmatched' lockers, but no big issues other than needing power steering now :doh:
The only real problem you will ever have with the birf's is when turning with big tires lots of traction, or hopping, If your birf's are in good shape and maintained they last a long time.
I agree on the rear locker too, I would like to get a front locker some day.
Good luck New-B :flipoff2:
Just put an Aussie up front and weld the rear - cheapest way to go. That's what i run and I had the aussie up front before I welded the rear - didn't have the 35s then though, I'll probably break a whole bunch of birfs from here on out - you have a lot more weight transfer when climbing that takes traction away from the front end and places more on the rear - that is the biggest reason most people run only the rear end locked - better bang for the buck if you don't mind an occasional heart attack when the thing pops while you're driving around town
i dont mean to hijack but, how long did your order for an aussie locker take to get to you? mine took 5 months, and i dont want to order if it'll take that long again.
