Master Cylinder
Hi Folks,
I have the original arrangement with a banjo bolt (not sure what thread it is) and would like to know what my options are to rebuild or replace with some kind of mod that will allow me to retain the pressure switch. Any help would be greatly appreciated.
Best to all,
Dura
Assuming you have a FJ25.
I have seen the newer single circuit master with the FJ25 master end cap and pressure switch used. OEM Brake Master Cylinder for '58 to '70 Land Cruiser FJ40 FJ45 - https://www.cityracerllc.com/collections/land-cruiser-40-and-55-series/products/oem-brake-master-cylinder-for-58-to-70-land-cruiser-fj40-fj45?variant=19703835328571 currently sold out but can be found other places.
I have used these guys to rebuild masters and wheel cylinders. White Post Restorations – Fine Automobile Restorations & Brake Cylinder Solutions - https://whitepost.com/#hometop
You can also rebuild them yourself.
FJ25 and FJ40/45 info. 25 Master Cylinders - https://forum.ih8mud.com/threads/25-master-cylinders.44958/page-11
Hi Folks,
Best to all,
Dura
Thank you for the responses. I forgot that the two master cylinders are the same, as my brake master was replaced with one that has the plastic cup. I rebuilt the clutch master about a year ago with the info from the link that you kindly sent. My problem now, is if I don’t rebuild the one I have, the banjo bolt arrangement is not common and I will need to rearrange the pressure switch and retube over to the first junction, which I probably should do as a long term solution. Again, I thank you folks for taking the time to help.
Best regards,
Dura
Thanks to @scoobiedubes
I am very curious how similar this MC is… Sure looks the same but it would be hard to know for sure without ordering one.
