Master Brake Cylinder question
My 1985 pickup 4x4 master brake cylinder is leaking. I want to know if anyone out is running something else besides oringinal equipment. I just bought it and have been getting it roadworthy.:)
You could try an FJ80 or maybe a Tacoma master cylinder, and do the IFS brake upgrade at the same time...there are write-ups out there on this...
Your master is 13/16" diameter. Early IFS V6 masters are 15/16" and later V6 masters are 1". You can run them, though you won't have as much pedal throw. You will probably need to tweek lines a bit. As I recall from my research the early 15/16" has different plumbing. Shoot, I'll shut up and send you to my write ups. Strongly recommend getting the master with the booster, and doing the vented brake conversion.
http://jonmarkstewart.home.comcast.net/85xcab.htm#brakes
http://jonmarkstewart.home.comcast.net/85runner.htm#brakes
Thanks for the input. Found a rebuilt one with a lifetime warrenty at the local auto parts. I paid thirty bucks for it instead of the 214.00 they wanted the Toyota dealership.:)
