Magnecor Wires.
Nevada.
Just installed a set. Very nice quality.
They only cost a bit more than stock OEM. There rated to 60k volts, and should be the last plug wires I'll need to buy.
Plugs are gapped @ .050" and running smooth as silk.
Dang…:eek: that’s a big heat dissipater on the ignition module, what else are you running on your ignition?:hhmm:
Just the coil and Denso TT plugs gapped @ .050".
I just use arctic silver epoxy to add the heat sink, as an added measure of safety.
The heat sink is warm in 5 minutes and near hot after 15 minutes, so I'm sure the power transistors are smiling with less heat.
Coil and plugs made a big difference with cold starts and a feeling of overall smoothness.;)
Cool to see 'em installed in a 62. A set is on my list as well as an upgraded coil and a DUI igniter (with an old Alpha heatsink if I can track one down). Gonna lose this Mallory box and reclaim the real estate that desmogging originally bought me on the driver's side :D
Got them here, Magnecor Spark Plug Wire For Toyota
They ran $71.55(80.75 shipped). They drop ship from Magnecor, so you know your getting the real deal.
I will call Magnecor on Tuesday and inform them that the #1 wire is on the short side. I will see if they can revise the model and correct that.
Needs about 1~2" to be just right, instead of a little tight. Coil wire is on the long side(by about 6").
like the 'ol P300 @450... AS5 FTW! nice.
Better price than going direct? Magnecor sold direct when we used them on a dyno project.
FWIW We used the Magnecor cables after MSD cables failed to suppress an RFI/EMI noise problem that we were having. The Magnecor cables did the job. Was my first experience with them and the first time that I'd see the MSD cables fail to suppress. If I didn't have a free brand new 25' roll of MSD cable I'd be tempted to use Magnecor on "Wallace."
Direct would be a little over $100.
For me it was about running a wider plug gap, and not killing the wires.
I got a set of Accel wires, and I could hear spark noise on my AM talk radio(really bad under the overpass). The accel's went back the same day.
I then did some Net research. Magnecor kept popping up. I gave them a try, and no noise! Very well made.:)
Resurrecting this thread since I about busted one of my old Accel 8.8mm wires today while changing out my cap and rotor and thinking I'll go ahead and order a Magnecor set at the end of the month when I get an extra paycheck. @Benjaman where did you source the heatsink you put on the igniter? With replacements getting more and more rare (and DUI igniters unavailable anymore, which led to me keeping my Mallory 6A box), I want to do what I can to protect my OEM igniter, which right now sits on a custom mount I built for the Mallory Promaster coil I installed years ago.
I'm due to replace the plugs as well soon so I'll be installing a set of NGK Iridium plugs with indexing washers along with the Magnecor wires. Given the upgraded coil, Mallory CDI box, new cap and rotor and soon to be ordered Magnecor wires, I need to figure out a good gap to use for the plugs. I've been doing 0.035" but I'm considering trying 0.040" and seeing where that gets me.
