An original TUT Trailer Build...ahhhhhhhh..how cute!
valentine said:I have a stock set of mini springs you can have if you want them.
Next up is a new axle/hubs, slightly wider than whats on there now.
then:
Set up the sink
water tank with faucet
bedline the inside
battery with solar charger
some LED lights and charging ports
otherwise, once the water tank is framed in, I'll take the bed off and sand down the frame so I can clean it up and repaint it.
I would like to add about 1 inch or so of lift to the suspension. Whats the easiest way to go about that?
Will you be using the style water tank and faucet as your old AT trailer?
For a little lift seeing how you are spring under, longer rear shackles. Something you can make pretty easy.
Nice to see you back fabbing![]()
