oh no kidding - where would i find aftermarket gears/motor?
I haven’t done the full research, just a cursory glance and saw that there were various motors or gear sets listed on Google for our trucks. You’d probably have to dig into yours to see what it needed. I’ve also had success, cleaning out similar motors and reassembling them. My left mirror is slightly slower than my right mirror so at some point, I’m sure I will dig in, but I’m definitely not buying anything new oem…oh no kidding - where would i find aftermarket gears/motor?
Any chance you took a pic of the broken wire? I have similar issues. Mirrors don't point down in reverse, only the drivers folds but both unfold if I fold the passenger manually. Would like to get this sorted as I need to reserve into my parking every day.My issue ended up being a broken wire in the driver door. Had to remove the panel and found it there. Once repaired, everything came back.
Is the mirror adjustment selection switch in the right position? In the center there is no tilting and depending on whether you have the switch to the left or the right depends on whether just one mirror tilts down or both mirrors tilt down.Any chance you took a pic of the broken wire? I have similar issues. Mirrors don't point down in reverse, only the drivers folds but both unfold if I fold the passenger manually. Would like to get this sorted as I need to reserve into my parking every day.
Anyone else solved this issue?
Checked switch position again and this time every worked as you described, thanks heaps!Is the mirror adjustment selection switch in the right position? In the center there is no tilting and depending on whether you have the switch to the left or the right depends on whether just one mirror tilts down or both mirrors tilt down.
