- Thread starter
- #21
Hello Again! Here's my progress (Max 20 minutes). BTW: my Husky 3-position ratchet screw driver came in handy. It's now a matter of waiting for the new ignition switch to arrive.
Thanks! Yeah...I'm there for sure. I just swapped out the Ignition Switch....and still no clicking. Regarding BILT4ME's point about the starter;As long as you are that far into the dash, as @BILT4ME suggested, this is a good time to remove the RS3000 factory alarm if you have it. You are over halfway into where you need to access and removing it gets rid of several potential points of failure that can keep the vehicle from starting.
Use the first part of the thread below to walk you through the uninstall.
HOW TO: Detailed DIY for Remote Start/Alarm/Keyless Entry
I've swapped the starter too from O'Riely's Auto Parts. Man! I feel stumped.I'll bet if you're not getting a click but sometimes it starts if you hold it, it's the starter that needs a rebuild kit or get a reman Denso from rockauto.
I also have a starter from O'Reillys. It has lasted two years And is doing the same thing on mine occasionally.Thanks! Yeah...I'm there for sure. I just swapped out the Ignition Switch....and still no clicking. Regarding BILT4ME's point about the starter;
Sure....I can do that. It's just so weird that it doesn't want to produce any clicking noise or show a draw of energy at the battery gauge.I also have a starter from O'Reillys. It has lasted two years And is doing the same thing on mine occasionally.
Can you get under the truck, smack the starter with a hammer or the handle of a break over bar and it start right up?
Mines doing that and the starter is less than two years old.
If it works to do that, it's definitely starter and nothing else.Sure....I can do that. It's just so weird that it doesn't want to produce any clicking noise or show a draw of energy at the battery gauge.
Gotcha! I'll have to recheck to see if current from the Ignition Switch is getting to the starter. The starter is definitely getting power from the battery....but the Ignition Switch is not completing the electrical circuit to engage the starter. I'll update as I progress.... Thank you!If it works to do that, it's definitely starter and nothing else.
So I am still thinking have you removed that alarm system, I have done several diesel swaps and every time we had a starting issue we pulled that RS3000 out and boom our problems solved, it is the alarm not letting the power go to the starter ................................................................
It was the Theft Control Relay, which caused an electrical short in the wiring. I spliced the wire and by-passed the OEM factory theft control module. Thanks!
Is that the one under the driver's seat?Happy New Year Everyone! Well, I found the culprit that was keeping my rig from starting. It was the Theft Control Relay, which caused an electrical short in the wiring. I spliced the wire and by-passed the OEM factory theft control module. Whew!!!!!! Thanks to all for your awesome feedback..
Actually, it's the one under the dash...behind the fuse panel. My LX450 fires up real nice again. I love that machine. Thanks!Is that the one under the driver's seat?
Do you happen to have a pic of it?Actually, it's the one under the dash...behind the fuse panel. My LX450 fires up real nice again. I love that machine. Thanks!
