This afternoon I installed the Prestigious Society navigation bypass...
I initially unhooked the negative lead to the battery:
I noticed that the connectors were corroded so I just unhooked them both and sprayed them down with RODI water. I then used a wire brush and rinsed.
Next up I started removing the door trim, it was rather easy as you start at the bottom and pull out:
Next up was the mirror controller, also rather easy by pulling away from the dash:
