Lumen figures for ALL lights?
jaymar
SoCal
Planning to switch to LEDs and wondering what the stock light lumen output is. I wanna go brighter all around (not just headlights) and maybe on the interior as well, but not blinding-bright. Anyone here ever measured this or tracked it down?
Thanks for any help!
lumens is only part of the picture. The direction of the beam matters just as much. Certainly for the headlights and even arguably for the interior. And the wavelength too.
It is hard to measure lumens. Luxes OTOH is easy.
I don't recall ever reading lumens figures for our trucks, even for the headlights. But maybe on the site of a good replacement bulbs place?
I wonder if the bulb mfrs were measuring lumens in '95? If so, and the bulbs were specced to lumen output, problem solved.
This post is only in reference to the dash lighting.
LED's have a very narrow operational rage when using a voltage source as a power supply, there is a difference of only 1 volt or so between on and off, in electronics we call this non linear. So if you are using the factory dimmer circuit you could have a situation where you dash lights are either too bright or almost off.
A nice solution is installing a PWM (pulse width modulator) it varies the how fast the led flashes on and off and our eyes perceive this as the light dimming. PWM's are available for around 40 bucks, its just a box with wires and a knob and could be subbed in place of the factory dimmer.
Personally I think the stock incandescents are superior to LED's for dash illumination. All the conversions I've seen have hot spots on the dials. I have heard of some filing down the lens in a attempt to diffuse the LED's light more evenly.
This post is only in reference to the dash lighting....
Thanks for the info; dash lights are last on the list, may be too much trouble but many thanks for then info. Is this related to the hyperflicker issue sometimes seen with LED tun signal lights? i know there's a fix for that, but haven't researched it yet. Another Q: can the PWM be used as a dimmer for any LED/LED group? Interesting stuff!
Too many imported products and no realistic industry standards. I've seen 24000 lumen light bars that are dimmer than 15000 units. They are
probably comparable only within the same manufacturer. Cree and Osram build most LEDs and a 3w cree LED is only as good as the circuitry feeding it and the real illumination is only as good as the reflector.
I'm not familiar with the blinker situation.
The PWM dimmer units come rated in amp draw (10 amps is common) so i don't see a reason why you couldn't also do the interior dome lights on one. Not sure where it would be mounted or the particulars of splicing into the existing wiring, but it would would very cool to have the option of selecting the brightness of the interior dome lights. I'm all ways dropping something in the truck at night and using a flashlight to find it.
O yeah I forgot to mention using a PWM for dimming tends to keep the color of the light consistent, just lowering the voltage will sometimes change the color a little.
One more thing Jarmar, I have no experience with the big stuff like head lights and the light bars like lcwizard is talking about. I only have first hand knowledge of the smaller interior stuff.
I have seen inconsistencies in LED's of the same spec form the same mfg., plus a small voltage drop from less than ideal wiring techniques can produce uneven lighting within a given lighting fixture.
Thanks again; interior lights on a dimmer would be very nice. Hyperflicker is (according to my current understanding--no pun intended) apparently caused when the LED voltage draw is so low, it causes a drop in circuit resistance (the turn signal relay "thinks" the bulb has burned out, which also causes a drop in resistance)--and you get this extremely rapid flicker. There are several ways to address this, one of which is adding a load resistor.
It seems about half of MFR's measure their lumens at the LED, while the other half measure what's known as OTF or "Out The Front". I find this to be a more meaningful number as it demonstrates just how much light is actually making it out of the device. For example, everyone and their mother knows how many lumens a standard XM-L2 emitter puts out, but its nice to see just how many lumens are making it past the reflector, lens, etc.
I did an output comparison of stock verses HIR
Testing HIR lamps - What I found
Dont know if it will help
Higher kelvin can produce higher light levels but the increase brightness does not always transfer to better night vision.
China kelvin and output is in most cases far from accurate.
Because most LED is 5000k and above it lacks high CRI something that makes the HIR lamp great IMO
Have a guy at an aftermarket bulb co. running these down for me, but he says there appear to be different interior stock bulb options. Looking at the owner's manual, the info on these bulb #s is blank:
Interior lights
Personal light
Glovebox light
Luggage compartment light
Door courtesy lights
Vanity lights
Has anyone actually replaced these, or pulled them to look at them--and if so can you post year/model and the # on the bulb that came out (or the # in there now, but only original or identical).
Will be looking at my own shortly. Ultimately, I'm looking to put together a list of LED stock-lumen replacements, as well as stock+ and stock++ brightness.
