Lowering Battery Terminals?
jaymar
SoCal
Have two Odyssey 31-PC2150Ts here with a '95 Cruiser. Put one in the stock location, and the negative terminal is extremely close to the underside of the hood. (I'll have the same issue when the second one goes in.) I have a temporary insulating cap on it, but the hood hits the cap when closed. I do NOT want to relocate the battery or put it on its side, and ditching the factory tray means a rougher ride for the battery so I'm not fond of that either.
Which leaves the terminals. Grind 'em down or replace with shorties, and use low-profile or ring-type connectors. Thought I'd run this by the Brain Trust and see what comes up...
Both terminals meet SAE J537 spec, which dictates all dimensions. Threads are 3/16 UNC 2B.
Anyone running or know of shorter terminals that will work here, or is it grind-time?
Thanks for any help!
Hmm, close is fine. So is having it be the negative terminal. Mine is also close but since it's actually not touching I haven't given it much thought.
Less than a quarter-inch--and the thickest part of the negative connector is actually higher than the terminal itself, so I've placed that inboard. Just not a setup I'm comfortable with. (Standard clearance is supposed to be one inch.) As you might imagine, the Odyssey tech I consulted is not exactly laid-back about the situation--bandying about terms like "5,000-amp short," "hood melt-through," "fire," etc. etc.
I had the same battery in my 60 and it actually did leave a mark on the hood. It was the outer negative terminal, but I
decided to remove the battery and wait for a means of getting the battery lower.
I did contact the tech guy at Odyssey and they in fact suggested to me to just trim the threaded stud.
Did you look up StainlessSteelTrays? They make battery trays and may have a bolt in that is specific to the
80 for the 31 series battery. It costs about $100 though. But that would be the thing if you are determined.
Interesting; I'm hearing things like "void the warranty" if terminal ground down or even replaced with another of the same. Thanks for the tray tip (will keep in mind if it comes to that)--but I'm thinking the stock tray material may provide a bit of "bounce" that a flat steel tray will not, and I want 10+ years out of these.
From everything I've seem, the people who buy the trays have no issues. In fact by the looks of it, the hold downs
are probably better than factory. I can't speak from experience though
So your worried about the Negative post touching the hood/body? Isn't your rig negative ground? Doesn't the negative cable connect the battery to the body/frame anyway?
Umm, that's if it's the positive side.
Since the 2150 terminals are screwed on, they can be adapted as needed without affecting the battery warranty. So cut them down as needed.
Plus, I would be a lot more concerned about the positive terminal than the negative terminal as the body and the negative terminal have zero voltage difference as inkpot rightly states.
I've got a very thin insulator on it, and when the hood locks, that side isn't all the way down. So it's holding the locked hood up. Which means there's downward pressure on the terminal--not something it's designed for. The terminal may even be touching by itself, with no insulator. So, that's how tight the fit is.
And of course the hood gap on that side may bend the hood--and let rainwater in. Not a pretty picture.
Will def look into these, but I do like a non-conducting tray. J-bolts and hold-down have to change out anyway, new or fabbed. Thinking to reinforce the inboard side with metal outside the batt compartment, as the inboard hook anchors only on the battery box.
Since the 2150 terminals are screwed on, they can be adapted as needed without affecting the battery warranty.cut them down as needed.
Yeah, positive seems okay, but I'm gonna go with something like a Toy-style connector anyway, to get rid of the bolt that now sticks up above the positive connector and the terminal top.
Battery is flipped, so negative terminal is closest to the driver's side. I did tell him that.
Yeah I'm gonna grind 'em and look for lower-profile connectors. For anyone interested, this is straight from the company:
Both terminals meet the specifications of SAE J537. Attached is a copy of the spec. sheet which notes the dimensions.
Correct , there are different terminal configurations for the PC2150 battery. The T is for SAE post (spec. sheets attached) and the S is for the stud terminal which is installed during manufacturing and not sold separately. [I had asked about other 2150 terminals that might fit.]
A small drop of thread adhesive (loctite 277 or 271) should be applied to the battery terminal posts prior to installation of the SAE terminals. The torque for each post is 110-120 in lbs, 200 in lbs max.
We don't recommend the removal of terminals that are already installed on the battery , the removal voids the warranty.
[Technically, I suppose one could grind the terminals ON the battery, if one were so inclined (which I am not).]
Okay, so, the battery posts aren't coming off without a torch (550 degrees to loosen the thread locker), so if I want to lower the negative posts, that means removing material with the terminals in-place. ("The SAE terminals on the 31-PC2150T are made of solid free machining brass grade and are screwed onto the stainless steel stud and fastened to the stud with red Locktite as a thread locker so the SAE terminal does not unscrew on the stud.")
Can't say I've ever done this before, so thought I'd ask for opinions...
What method is least likely to harm the battery's internals?
Hand file
Cut / slice / shave (and with what tool?)
Saw
Power grinder
Powered wire wheel
Dremel
Other
Should post be clamped in some way to minimize torque/vibration?
At first glance, cut (and file or grind/Dremel to smooth) seems a good bet...
If the posts are lead, the soft metal will clog up just about any electric grinding tool I know of.
A course bastard file would be the best manual method in my opinion with very regular cleaning of the teeth.
A Dremel with a wood cutting blade would be my choice. Just take it slow and easy. A fast speed would minimize harmful vibration.
Remember that the 2150 is a gel cell so it can be placed in any position so you can work comfortably and even more important - SAFELY! Protect the terminal you are not working on the best you can - PVC pipe or piece of dry wood over the terminal to protect it from accidental shorting.
The short circuit amperage is 5000A if memory serves me correctly. BE CAREFULL! A mistake can hurt or even kill someone.
If you are not sure that you can accomplish the task, don't do it.
I once saw a 12" long 3/4" wrench dropped on a series of 2V 800A batteries in a telecommunications pack. It vaporized the wrench with a very loud bang as it touched the positive and negative terminals simultaneously.
Yes, 5000A, as Odyssey keeps telling me on these AGMs. Plan to cover other terminal to prevent short from metal dust as well. Posts are made from solid machining grade brass, says the company--would you still recommend wood blade (wheel?)? Can't say I've ever done this kind of thing before... Thanks!
Make a clamp out of a piece of hardwood. Drill the correct size hole for the terminal to fit in and slit the end so it goes on like a terminal clamp. Adjust the thickness of the hardwood to the height you want for the terminal. Then use a Sawzall or jig saw with a METAL CUTTING BLADE. A hacksaw would do it by hand and even a coping saw will cut brass. Go slow and make a sawing motion with the blade to keep the gullets of the teeth clear.
When you're done, use a file or some sandpaper and clean off the burr. Be patient. Keep the opposite terminal covered with heavy plastic or something. And consider clamping the battery to a workbench or something to keep it stable.
Ymmv
Thanks for the additional tips! Someone suggested an interesting alternative: heat the battery post with a soldering iron to break the threadlock, remove the post, slip an eyelet cable terminal over the 3/8 stud that leaves. This cuts height by almost 3/4".
Anyone see any safety issues with this approach? According to loctite, it takes 550 degrees to loosen the grip...
I would just worry about the effect of the heat on the plastic of the battery. I don't know if touching a battery with an iron like that will cause issues or not either.
Another option could be an insulator to cover the posts and keep them from contact with the hood. My FJC has a rubber boot on the red terminal for safety.
Or get a different battery that isn't so tall.
