Dunno; guy who suggested it works for a battery company, so might work. I'd rather cut down the post--but according to a custom cable guy I've consulted, there are no low-height clamps. Without that, no point to cutting the posts down, because the clamp hits the hood. I was thinking maybe one of those thin brass motorcycle ones (sort of a big C-clip with holes in the ends) could be ground down to half-height; can't do that with the standard car ones because I'll grind into the bolt hole. Not much thickness there though.I don't think a soldering iron is going to be able to provide enough heat fast enough to break the threadlock. The heat is going to dissipate into the rest of the battery very quickly. I would use a Dremel tool with a carbide bit.
Any pix of what you did?grind and cut the tray..have made the odyssey group 31 fit! but can't use factory tie down j hooks. you have to buy a piece of angle and use aftermarket j hooks from vat ozone, oriley's etc, etc
If you mean these guys(?), they don't seem to do 80's. Will email though... Stainless Steel Battery Trays for TOYOTA LANDCRUISERI had the same battery in my 60 and it actually did leave a mark on the hood. It was the outer negative terminal, but I
decided to remove the battery and wait for a means of getting the battery lower.
I did contact the tech guy at Odyssey and they in fact suggested to me to just trim the threaded stud.
Did you look up StainlessSteelTrays? They make battery trays and may have a bolt in that is specific to the
80 for the 31 series battery. It costs about $100 though. But that would be the thing if you are determined.
Or modify the battery. I'd prefer to do that since the tray will be there longer than the battery. All you need is a couple minutes with a Dremel and bit, the problem is solved - battery sits lower. Needs to be done to both sides.
Yeah, thanks, saw this mod in my forum searches, but the Odyssey's ribs are barely there [edit: ON FRONT AND BACK AND TOP OF SIDES; see new post below]. The 9.41" height is the problem.Or modify the battery. I'd prefer to do that since the tray will be there longer than the battery. All you need is a couple minutes with a Dremel and bit, the problem is solved - battery sits lower. Needs to be done to both sides.
Indeed--as the Odyssey tech duly noted when he saw the photo. Impressive....which is about how much I left![]()
Have two Odyssey 31-PC2150Ts here with a '95 Cruiser. Put one in the stock location, and the negative terminal is extremely close to the underside of the hood. (I'll have the same issue when the second one goes in.) I have a temporary insulating cap on it, but the hood hits the cap when closed. I do NOT want to relocate the battery or put it on its side, and ditching the factory tray means a rougher ride for the battery so I'm not fond of that either.
Which leaves the terminals. Grind 'em down or replace with shorties, and use low-profile or ring-type connectors. Thought I'd run this by the Brain Trust and see what comes up...
Both terminals meet SAE J537 spec, which dictates all dimensions. Threads are 3/16 UNC 2B.
Anyone running or know of shorter terminals that will work here, or is it grind-time?
Thanks for any help!
