Low Profile OBD2 Bluetooth adapter
Orlando, FL & Southampton, NY
I love using my ELM 327 adapters so much that I keep one in every car and a few in my tool box as spares cause I've been known to forget them in customer cars :doh:
For the last year or so, I've been using ELM 327 minis (smaller version of the full sized ELM 327), but I just picked up an even smaller adapter from VieCar :smokin:
I haven't had a chance to try it on my Cruiser, but I'm hoping that it's small enough to fit behind the cover for the fuse panel :hmm:
I did try it out on my XB and it works just as good as the ELM mini :)
Both DroidScan and Torque loaded up just fine without issue :cool:
$5 bucks shipped on EBay and worth every penny :grinpimp:
I tried and it didn't fit under the cover for me, how ever there is a low profile L shape connector that will fit under the cover.
That sucks :(
Did you try it with the cover removed?
My trucks at the shop right now, so I can't check until tomorrow :doh:
From the look of it, it probably will fit with the cover off. Actually I read your post wrong, I tried the mini but the new one should fit without taking the cover off. Sorry it's been a while, I'm using scan gauge now with the elbow connector.
Which scanguage and elbow connector do you use?
Update? I got a low profile one from Amazon and the cover pops right off. It's still a little tall and you can see how the right side of the panel is pushing out as I hold it in place. Looks like the connector itself may be able to spaced back a little? It wouldn't take much. I'll do that when I run through the po's awful wiring jobs :mad:
Does the Viecar interface even work on an 80? From the pics in post #3 it doesn't look like there is any connection on the PC board to the J1850 bus signal used in our rigs.
Yes, it works just as good as my ELM mini, however, I ran into the same fitment issue as Jake :(
The cover just doesn't have enough clearance:meh:
