Lost wire
TX
I have a '71 FJ40 that was "reworked" by previous owners. I pulled the instrument cluster out to fix a problem with the speedometer. While fixing that problem I noticed an orange wire with yellow stripe dangling loose. It has a shielded spade connector and comes out of the bundle that has the multi-wire connector that plugs into the console wiring connector. Any idea where this wire should be landed?
I don't think that's a stock color wire? Might be red/yellow
Thanks. I remember seeing this diagram but couldn't remember where. Now I just need to figure out how to download it...
Right click, "save image as"
Or you can just download the whole thing from here.
Here is a photo of the lone wire I'm talking about. I guess it could have been red at one time. Going with red, then it would be a red wire with yellow stripe. The multi-wire connector in the photo plugs into the connector from the instrument cluster. I only have one multi-wire connector attached to the instrument cluster. I notice in some online photos that some folks have two multi-wire connectors attached to the instrument cluster. Mine is a Frankenstein...
Good possibility it is part of the very crude early Speed Detector for emissions. Would be a spade on the back of the speedo head it plugs into.
Not a critical part of function.
