Looking for e locker swap instructions
Years ago I grabbed a front locking axle and the rear locking diff with intention of doing the swap. Bought all the switches, harnesses, dash lights etc, and found a really detailed write up on here by Overland?? possibly. Now I'm ready to do the swap and of course after 3 moves have lost the new harnesses and the write up. I can buy new harnesses but I cant find the detailed instructions anywhere. There are bits and pieces and many threads but this particular one went through the routing and connecting of all the wires etc and was very informative. Does anyone happen to have that thread or file saved? I have emailed the author but have not gotten a response. Just hoping someone here did a better job saving it than I did. Thanks!
I thought I wrote it up years ago. I'll be doing it again next month. I can take a few photos and write it up then. Basically you need to add 4 wires to the main harness running down the drivers side. Plug in the axle harnesses and plug in the 4wd computer and switch and away you go.
Installing is very easy. Just did it last week.
Simply swap the axles. Buy OEM wire that is under body. For the front one - it is begins from right side under bonnet and goes through right shock and on right part of stabelizer into the e-locker.
Connect the plugs.
Do the same with rear wiring. You need to find free plug for 6 pins under the body in the left side. Where the ventilation and sunroof tube goes outside from the body. There three plugs, some may be free. One for the ABS sensors, one for Adjustable OEM shoks and one for E-lockers.
!!! All wiring into the body exists in all models. (in japanese at least, in american i think the same) You only need to buy and connect OEM underbody wiring. If you dont wont to buy it, you can handmake them.
One more thing you need is the "computer 4wheel drive control" unit. That is plugged in the left sidepannel.
