I own a 100 now and have owned 2 80's in the past.
I love the 100 and it has taken me to some pretty cool places - for a 4 day trip to Death Valley last March - food, supplies, water, spare parts, tools, roof top tent and fuel - the truck weight was 7180 pounds!
Have you worked on the IFS? There are lots of moving parts - to get to the CV's if it breaks - hub has to come off - bearings - rotors & calipers - upper & lower A-arm ball joints has to come off - need a big hammer to get the CV's off the third member. You will need special tools for the ball joints - if the CV boot rips or cracks - you will also need a special tool for the clamps that keeps the grease from leaking.
The rear axle on the 100 is a semi-floater.
The 80 series front end - no special tools needed - a lot less moving parts - the rear axle is a full floater.
Being in the US - I would use the 100 for day to day, long trips, expedition trips - parts can be available readily and cdan is easy to get a hold offbut outside of the US, I would use the 80 - less moving parts in the front end - they have sold far more 80 series than the 100 series so parts can be easily obtained - even used parts.
I guess I have worked on the front end of the 100 many times - I have cracked the CV and had to replace it - in my garage, wouldn't want do it in the dirt somewhere where it might afffect someone else's vacation since they don't want to leave me there on the side of the road by myself. I've also broken birfields on the 80 - take the driveshaft out, remove broken birfield - lock the center diff and your on your way home. The 100 - you break a CV - unless you have another one with you, your options are very limited - you can take off the CV - be hard to plug that hole you left where the CV was and prevent gear oil from spilling out after you take the driveshaft off and push the center diff lock to get home or to a shop.
But I love the 100, lots of power, smooth, heated seats ...![]()
just my 2 cents ...
now that's a good lucid technically-specific point well-made...!
