locking down seat gear cap
Groveland MA
Website
landtankproducts.com
Most all know about the gear cap backing out which allows the worm gear to shift and strip out the white plastic gear. By the time you realize what is going on it's too late and I'm tired of dealing with it.
I figured that if that cap never loosened up the gears would last forever.
Here is my solution:
using a 5/64 drill bit pilot a hole at the seem between the cap and the hole in the housing. You will want to go about 3/8" deep and make several plunges as the drill bit clogs easily.
Then using a #4 x 3/8" sheet metal screw, screw it into the pilot hole until snug against the housing.
Then using a #4 x 3/8" sheet metal screw, screw it into the pilot hole until snug against the housing.View attachment 1220466 View attachment 1220467
This begs for a roll pin. Hmm...
great idea. Thumbs up.
One of those "why didn't I think of that" deals. Great idea! I'm doing it, thanks
I just use the soldering iron to melt, tack them together in a couple of spots. Enough to hold, be can be broken if future repair is needed.
Thanks Landtank! Great solution, as it's getting tiresome to lean over, press in the cap by hand and then move the passenger seat back/up. Once I change out the gears and screw caps will definitely add this "back-out prevention" modification.
Only in the 21st Century does someone think of this.... Brilliant.
Thanks @landtank!!!! Your timing for your post couldn't have been better!
My son drove my LC a couple times last week and I got back into it this morning and could barely fit between the seat and steering wheel. When it came time to leave work, I messed with it for a moment to see if I could make it move back, and succeeded in moving it forward another inch or two. By the time I was done, I had to lay the seat way back and to drop the seat bottom as far as it would go. My knees were against the dash.
When I got home after my secondary stuff tonight, I pulled the seat to find thee plastic gear cap laying inside the seat cover. I had read this thread a couple days ago and knew immediately what I had to do. I got things lined back up, cleaned and lubed lightly, and screwed in the cap. Then I trimmed a small spot to make an indent for the drill bit to sit in for a start.
I drilled it and found two very tiny screws and installed the first one on the driver's seat. The screw holds the pieces together an stops the cap from rotating.
GREAT JOB ON YOUR POST!!!
It took me about 30 minutes to pull the seat, drill it, screw it, and reinstall the seat. I'll do the PS this weekend!
