I've been having problems with my rear locker, the motor is fine (will lock with an 18v battery). The switch works as well as the wiring to the ecu, can lock and unlock with battery at the ecu.
My question is could the ecu be bad, there are 3 relays in it and the front clicks but the rear does not, although it did intermittently when I first started messing with it.
Any suggestions would be appreciated.
Thank you
Thank you
