Locked Rear Differential
Just took a test drive (on snow/ice and gravel). Rear diff is definitely locked. Tried activating/deactivating it, forwards, backwards, sharp turns left and right. Still locked. I'd like to remove the actuator cover and manually move the pin. Any pointers and pics much appreciated. Be back in a bit after my baby is in the garage.
It should be obvious if the rear is locked. Jst going around a turn, it will skip and jump all over. Chances are that it's unlock, but the sensor doesn't know it. I have the opposite problem - when I lock the rear, the blinks but won't go solid because the sensor doesn't know it's locked. Assuming it's not locked, you're fine. If it is locked, there's a thread around here for how to manually unlock it.
What the owners manual is saying is that you shoudn't engage the lockers if you're moving over 5mph. once you're locked, you can go whatever speed, though it would be unsafe to drive very fast with a locked diff.
I had this problem ones with my e-locker. Go to back axle were wire go for e-locker. You got to take the e-locker off the axle. Get a flashlight and flat head there is a pin you got to move over in the alxe. Put it back on and see if that works.
Make sure the switch/plastic plug is not bad or damaged back there. It happened to my front diff, it would not unlock because the front plastic plug was bad and it had to be rewired, something like $50 at the dealer. I had to drive about 1/4 mile through traffic on a curvy road in 4low with the front diff locked, that was fun. I would check the plug/wire, see if there is any damage, jiggle the plug see if it works. I have no idea if the front is the same as the back (I assume so), maybe it will work.
Had that same problem on my 80. Went home with locked rears, travelling about 80 or so kms without serious problem, though I kept speed at the very minimum under the circumstances.
Culprit according to the electrician was the computer controlling the elockers:confused::confused:. Accordingly, he bypassed the computer and hotwired the switch. Now its direct and have had no problems so far about 2 years since. BTW, my rig is a JDM with 1HDT matic, A442F tranny and K294 axle. From where I am, these computer boxes costs like gold if you find one.....
Im with checking the connections....My rear locker goes on the blink sometimes, and by that I mean the most recent trip I took a couple of weeks ago, I used my lockers and my rear wouldn't disengage, or so I thought. I drove it home after doing the "parking lot test" with no chirping of the tires and inspected it more fully after getting home.
Even though my light was kind on the fritz, staying on and then going off and coming on again, the rear wheels turned independently of each other. Check the wiring, I had loose connections.
Hoping to get some guidance here. 1997 Cruiser with front and rear locking diff's. Used them 2 days ago on icy hill after getting stuck behind a logjam of cars. Once home the front and center diff properly disengaged but the light for the rear diff stays on. Tried moving forward and backward, in and out of 4H and 4L with no success. Couldn't find another post about this issue.
Any ideas? How safe to drive as is?
A few questions if you don't mind:
1) Do you have a CDL switch?
2) If so, have you done the 7-Pin mod?
3) From what I gather from your post, you drove all the way home with all 3 Diff's locked, correct?
4) How far was this?
5) How fast did you drive with everything locked?
6) Does the ABS light remain on as well as the rear locker light?
7) Have you tried doing a panic stop in the snow to make sure the ABS is working?
1. No separate CDL switch, just switch with RR, FF-RR. Center diff engages after going to 4L.
2. No mods done.
3. Yes, Drove home with all 3 locked
4. About 250 yards, uphill, on packed snow and ice
5. Max speed was no more than 10 mph
6. ABS light turns off, along with the center and front diff lights
7. Yes, ABS seems to work properly.
