Hoping to get some guidance here. 1997 Cruiser with front and rear locking diff's. Used them 2 days ago on icy hill after getting stuck behind a logjam of cars. Once home the front and center diff properly disengaged but the light for the rear diff stays on. Tried moving forward and backward, in and out of 4H and 4L with no success. Couldn't find another post about this issue.
If it is unlocked, should be completely safe to drive. Are you positive it is unlocked? Inside the actuator there is 3 wiper switches, it may be that the shaft drove out far enough to unlock, but not enough to make the wiper switch. How long has it been since they have been serviced. It isn't too hard to do, but there are parts that Toyota doesn't sell, so if you take it apart be careful.
I am sure there are folks on here that have had this happen, and understand the system better than me and they can confirm or reject what I am saying. Just letting you know what I have seen in mine.
The light for the rear diff is the only one staying on. The center diff turns on in 4L and the front diff light turns on when the control switch is switched to FF-RR.
The rear diff cannot engage without the center. If you try to engage the rear without the center being engaged, the dash light will just blink.
Is this what is happening, or is it a solid indicator?
Is the center and ABS light on?
If it engaged properly, and now just wont disengage, that I'm not sure about. If the dash light is on solid, I wouldn't risk it by driving on a hard surface.
I'm pretty sure it means don't try to engage it above 5 MPH, you should be able to go faster than 5 MPH.
But you need to be sure it is unlocked, you can drive a tiny amount (don't leave your driveway) to see if it is still locked. If it isn't you should be good to drive.
If you haven't used it in a year it is probably sticky in there, and if it hasn't been serviced chances are the factory lubricant has dried up inside, making it difficult for it to work properly. Kind of surprised it locked for you.
Also, is the RR light steady or flashing as SDNative asked. I think you mean it is steady. Again, probably just stuck and not making one of the switches, if it truly is disengaged; if not don't drive until fixed.
If you have questions about tearing it apart PM me.
The rear diff light is steady on. In 4L with the center engaged the ABS, front and center diff indicator lights both turn on (in addition to the rear diff light which is not turning off). I have not tried to activate the front or rear diff without first shifting to 4L and activating the center diff.
How can I tell if the rear diff is remaining locked (and not just the light staying on)? Would it help any to drive a small amount at slow speech with all diff's on, then try to disengage again? Just don't want to cause any damage or further damage if it can be helped.
yea,
to find out if the rear is really locked, go turn a sharp right turn slowly in a parking lot.
you will know real quick if you are locked or not. chirp chirp chirp chirp chirp.
People run spools all the time in rigs. its annoying, but at least it wasn't the front axle not unlocking. that would be painful.
Spool is another way to lock up, don't worry about it though, you have the almighty E-Locker's so your good to go. Do the wheel in the air test or drive it to check and see if it is locked, if you do drive just do enough turning at slow speed to determing if you are locked. That will be your first priority. Can't do much else at this point until you know if it is locked, other than cleaning terminals on the plugs, but that won't matter much if you need to service it.
Drive forward and backwards in circles (try backwards first). Once in a while my rear locker does not disengage immediately. I back up a bit with the front wheels turned and it falls out quickly. You'll hear a thunk. You may not have much luck driving in a straight line. They lock/unlock much easier when the axles are turning at different speeds.
Try locking it back up and unlocking it again. Can you hear the actuator motor? You may need a friend to stand near the back of the truck to listen.
Any ideas? How safe to drive as is?
