Little things….between bigger projects.
Deep East Texas
Noticed my license plate lights were not very bright and upon inspection one of the two bulbs was burned out and the lenses covering them were dull and stained beyond help (cleaning). So I ordered new lenses and gaskets.
To help things further….I installed #194 type LED bulbs.
Good bright light NOW!
Added benefit…is it casts a light behind the vehicle that is useful for seeing back there at night (loading groceries, hooking up my trailer, etc).
Added benefit…is it casts a light behind the vehicle that is useful seeing back there at night (loading groceries, hooking up my trailer, etc).
Thanks for posting the part numbers! Those are going in my next order.
Yes, thank you. I have a wiring issue back there as mine are dead right now, but when I dug into it, there were a bunch of compromised parts. I need to find the short, first, but after that, getting new junk will be key.
Not an attempted thread-jacking here but, today I ordered all the rubber bits and belt moldings for all doors and windows, front to back, from an online oem parts distributor and it seems the inside belt weather strip for the rear passenger entry doors is not available. Does anyone know where/how to procure this part?
@flintnapper, thanks for the reminder on those lights as they are easily forgotten until the cops pull you over.
Inside belt weather strip- 68190-60010
Would @beno know where or if you can find the inner belts? @cruiserdan ?
My parts cleats are hanging up in the display case. They got retired almost a year ago.
Now that is out of the way, 68190-60010 is an old number.
Current numbers:
RH, 68190-60011
LH, 68240-60050
Flint where did you get your bulbs?
If you Google the part number, there are a few OEM pages that have it in Stock. 68190-60010 - Genuine Lexus WEATHERSTRIP ASSY, REAR DOOR GLASS
$15.11
I doubt they really have them. The suppression is old.
Hey Dan, good to hear from you.
Hope you are enjoying your new position. I am retired now and need to make a road trip up that direction one day. Hope to see you then.
The bulbs (194 style) are available from a number of sources, but these came right off the shelf at WalMart. Darn things are super bright.
I did not take the time to paint the inside of the bulb housing silver (to reflect light) but I don't think it needs it. So nice to be able to see behind the vehicle at night when I go to open the tailgate or hook/unhook a trailer.
Take care my friend,
Flint.
I was eying the Wally ones and this tells me they run well. Hopefully your new found light is not too much for LEOs to complain about.
Current numbers:
RH, 68190-60011
LH, 68240-60050
I know that they are hanging and gathering dust now........
I also knew that you'd know the answer!!!!!!
You came through for all of us again!
The light is projected downward and out to each side because of the shroud the light fixtures sit in. It doesn't create a 'glare', just a nice soft light that reflects off the vehicles paint and license plate. It only illuminates the area directly behind the vehicle.
LEO would be hard pressed to make a 'case' that would hold up in court. They can stop you for any number of made up reasons.
Not an issue where I live. I'm out in the country...and when I do venture into the 'one dog town' nearby, I know everyone. A 'ticket' or getting stopped is highly unlikely (for me).
Current numbers:
RH, 68190-60011
LH, 68240-60050
Hi Dan!
I am trying to order these for my 96 LC and the LH one, is listed on the website as 68190-60010 which, as you stated has been updated to 68240-60050.
When I try to order the 68240-60050 number, it tells me to "Call for Availability."
The site also shows the part number for BOTH sides is the SAME number (68190-60010), so, should I just order two of P/N 68190-60011? Will that get what I need?
That site information is outdated. 68190-60010 IS NO LONGER AVAILABLE. It has been replaced with side-specific parts. It may be possible to put a 60011 on the left side but it will not be correct.
Thanks Dan!
I'll post what happens on fitment of the 68190-60011 to fit BOTH sides. It may work, it may not............
It'll be a while, as I will do the front doors first. It takes me forever to get anything done.
I just noticed one of my license plate lights burnt out. I ordered the bulbs, lenses and gaskets. Thanks for posting the part #. Unfortunately, my screws are beyond rusted and also need to be replaced. I'll probably ended up breaking the old lenses to remove them.
Anyone know the length and thread to replace the screws? I assume all 4 are the same.
